Wiring diagram
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25941
Printed Date: April-05-2025 at 11:20pm
Topic: Wiring diagram
Posted By: Potlatch
Subject: Wiring diagram
Date Posted: May-10-2012 at 9:53pm
Where would I find a wiring diagram that shows dashboard & gauge wiring? My manual shows engine wiring, but I want to correct some of the under-dash stuff that previous owners had done. Thanks.
Posted By: Bri892001
Date Posted: May-11-2012 at 12:21pm
Welcome to the site,
You mentioned in your other post that it's for a 91 (It's good to keep all responses for a subject on one thread)
Unfortunately the closest you're going to get for a 91, is this diagram for an 89: http://www.correctcraftfan.com/downloads/1989_SN_Wiring_Diagram.pdf" rel="nofollow - http://www.correctcraftfan.com/downloads/1989_SN_Wiring_Diagram.pdf
There aren't major differences though.
Posted By: N2Deep
Date Posted: May-11-2012 at 2:21pm
I have my whole dash apart right now and can help ya with whatever your trying to do. I should be putting it back together this weekend after repairing the plastic. So let me know what you need before i get it all back in the boat.
------------- 1991 SN pulled by a 2010 Tundra
Date Posted: May-11-2012 at 2:30pm
Craig, could you post some general pics? Especially a rear view of all the gauges and everything from behind the dash?
Posted By: N2Deep
Date Posted: May-11-2012 at 3:31pm
Yup will do tonight when I get home if I can get it back together tonight. Anything specific you need? I will take some with it taken apart and then a complete one when it is back together.
I used the Plastex repair kit and it worked very well - just have some sanding to do so and glue the fabric back on in a few small places. Now my dash is in really good shape and no cracks or broken pieces - just a couple crappy looking gauges that need replaced. LOL
Posted By: N2Deep
Date Posted: May-11-2012 at 3:33pm
I have gone through ALL the wiring in this boat so can tell you where any and every wire goes. A few late nights and lots of fun Just about ready to start putting her back together and get her on the water.
Date Posted: May-11-2012 at 4:05pm
I'm mostly interested in the wiring. I've run a new ground and cleaned some things up on mine, but I think it's going to need a thorough run through.
Posted By: N2Deep
Date Posted: May-14-2012 at 2:21pm
Sorry this post got screwed up had to repost.
Posted By: N2Deep
Date Posted: May-14-2012 at 2:22pm
Here are some pics but not sure its gonna help ya rewire something because some of the wires are the same color that go to different gauges.
Let me know if you have any specific questions and I can try and help https://picasaweb.google.com/100373035240749532488/1991SkiNautique" rel="nofollow - 1991 Ski Nautique
Date Posted: May-14-2012 at 2:36pm
There's more stuff than I realized going to the temp gauge...
I figured: -hot (ignition) wire -ground, -sender -lights
I guess everything is daisy chained, so some of those bundles represent one connection. It still looks like a lot. Does one wire go to the alarm or something like that?
Posted By: N2Deep
Date Posted: May-14-2012 at 3:24pm
On the Temp gauge you have your grounds and backlight. Then the browns go to the Temp sensor and the purples are power, alarm and the temp warning light. I can trace them out for ya if you want- while I have the dash off. Its kinda hard to take pictures and trace the wires from a pic. Let me know what you want traced and I can get it done tonight.
Date Posted: May-14-2012 at 3:37pm
Ok, thanks, that helps. No specific questions. I have that Faria replacement temp gauge, that I've yet to install. My old one allowed moisture in and is kind of fogged over. But, it doesn't use the same spade connectors, so it's not exactly plug n play.
Posted By: Potlatch
Date Posted: May-14-2012 at 6:04pm
Thanks all.... think I've got it figured out.
Posted By: hoch323
Date Posted: May-24-2012 at 3:08pm
N2Deep posted some nice pictures of the wiring on the back of his gauges. Are black wires in the pictures always ground?
Date Posted: May-24-2012 at 3:33pm
hoch323 wrote:
N2Deep posted some nice pictures of the wiring on the back of his gauges. Are black wires in the pictures always ground? |
Dave, The black ones should be ground but you never know who's been in there messing with things. You'd better get the VOM out and check. I ALWAYS do before having a problem.
Date Posted: June-06-2012 at 5:56pm
Craig,
I was looking at your dash wiring pics again. I had one question about the temp gauge area:
-The group of Purple wires on the gauge is the ignition daisy chain -The group of Black wires on the gauge is the ground daisy chain -The group of blue/white wires on the gauge is the lights daisy chain -The group of brown/tan wires on the gauge is the sending, right?
I see another grouping of two blacks, poking in near the purple ignition. Do you know what those are for? Or is it just the pic that makes it look like they're connecting?
Thanks, Brian
Posted By: N2Deep
Date Posted: June-06-2012 at 8:04pm
The set of black that is with the set of Blue is the ground for the back lighting or gauge light. The black that is behind the purple is the ground group for the gauge. Hope that helps
Date Posted: June-06-2012 at 8:20pm
N2Deep wrote:
Hope that helps |
Ahh, I get it now.
Makes sense... well, I understand it anyway. So, the light for the gauge, is treated as it's own separate component.
