Tee Nuts
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25960
Printed Date: November-19-2024 at 2:40am
Topic: Tee Nuts
Posted By: winniskier
Subject: Tee Nuts
Date Posted: May-12-2012 at 10:09am
I had the upholstery re-skinned over the winter. I removed the pieces from the boat myself and delivered them to the upholsterer. The piano hinge at the top of the observer’s seat was anchored by a screw into a tee nut attached to the backside/ inside of the seat frame. The tee nuts had loosened up over time. Rather than fix or replace them, the upholsterer removed them and suggested wood screws. To me, this is not optimal since they have greater chance of loosening up in this type of use. I now can’t get access to the inside/backside of the seat frame, so tee nuts are not an option. Any suggestion as to what I could use that would be the equivalent of the tee nuts?
Jim
Date Posted: May-12-2012 at 11:35am
Jim,
The T nuts are in there since wood screws or even fully threaded type "A" sheet metal screws won't handle the load. I suggest removing enough staples to get the T nuts back in the ply. If they are loose, epoxy them in.
It sounds like maybe the upholsterer should have put in new wood?
Posted By: SNobsessed
Date Posted: May-13-2012 at 10:53am
Take a large hole saw & cut a plug around where the Tee nut went. Make a mating plug to refit, putting the tee nut in that. You might want to epoxy in a couple of thin wood 'slats', off-center of the hole (a door frame shim would work) to give a back stop. Then epoxy the plug back in. It would have been much easier to replace the wood when the skin was off!
Posted By: 81nautique
Date Posted: May-13-2012 at 11:25am
If we're talking about the 97 in his avatar he doesn't have wood for seat backs. He doesn't mention wood in his post just wood screws. I would remove the staples and either insert new tee nuts if possible or attach a 1/8 thick backer strip of aluminum or stainless and through drill and fasten with nut and bolt if there is room.
And then go tell your upholstery guy he's a morron.
Posted By: lewy2001
Date Posted: May-13-2012 at 11:47am
Yeh Alan sounds like he has a 97 no wood.
Jim not quite sure what the problem you are describing is do you have a picture of it?
But the interesting info in the diary entry was that he actually sold JoeinNY the future worlds fastest SN2001.
Date Posted: May-13-2012 at 11:00pm
Yes, it is fiberglass. I turns out that it is not the problem that I expected.   The tee nut does not anchor on the hard backside/inside of the upholstered panel. The hinge connects to the fiberglass seat structure, then the upholstered panel attaches by a separate fastener to the seat structure.   I can attach the hinge using nuts and bolts.
I’ve run into this issue a number of times with other boats. The above advice will come in handy next time.
Yes JoeinNY did take the world’s slowest SN2001 off my hands so I could buy the boat that I should have bought the first time. All good now.
Jim
Date Posted: May-14-2012 at 12:01am
Jim - Sorry for my left-field answer. I can see how the tangs of a tee nut wouldn't dig into fiberglass. Poor design from the factory in the 1st place.
Date Posted: May-14-2012 at 9:57am
Epoxy in place:
Posted By: Bri892001
Date Posted: May-14-2012 at 1:31pm
"Tee Nuts" would be a good stage name for a rap star
Posted By: nautique frk
Date Posted: May-16-2012 at 4:52pm
Yo Yo Yo What up "Tee Nutz" !! Newest Rapper :)
