GT-40 starting problem solved...
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=26249
Printed Date: November-19-2024 at 1:36am
Topic: GT-40 starting problem solved...
Posted By: ultrarunner
Subject: GT-40 starting problem solved...
Date Posted: June-01-2012 at 12:03pm
So, as we discussed in Common Questions I think, I explained that my fuel pump (GT-40/EFI) was not priming when key turned on, and was intermittent. Also had an occasional complete engine cut-out when driving.
The suggestion was the relays at the ECU. Auto zone only had one, so I replaced the inboard relay, and all seems well after several dozen starts, etc. I'll swap the other for good measure as they are 13 years old.
I'm usually apprehensive of just changing parts, preferring a definitive diagnosis, but the relays are cheap. We'll see if the problem is cured. I haven't pulled up the schematic, what all is on that relay if someone knows off-hand.
Thanks,
Ultra
Date Posted: June-01-2012 at 12:49pm
Posted By: Bri892001
Date Posted: June-01-2012 at 12:51pm
In this thread:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25584&title=poor-mans-gt40-diagnosis" rel="nofollow - http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25584&title=poor-mans-gt40-diagnosis
Lewy2001 mentions all of the correct relay part numbers.
I'll log your fix as well.
Date Posted: June-01-2012 at 4:53pm
Ok, so, I took a look at the PCM GT-40 manual today, and it would appear from the diagram on page 3H-5 the Fuel Pump relay is closer to the ECA than the EEC System relay. In which case I replaced the former. The one from Autozone was not a Hella, but got be back on the water. Is it generally accepted to replace both these relays with the OEM Hella-brand units or are the cross-referenced units adequate? They're cheap enough I don't mind ordering a couple more.
Thanks
Date Posted: June-01-2012 at 5:24pm
I'd go with a name brand - Hella is a good relay. They sure must be pushing the amp limit on the contacts considering how many problems everyone has with them. An alternate would be looking for a relay with a better amp rating. Are the bases for the relays a standard auto configuration?
Date Posted: June-01-2012 at 5:35pm
Thanks Peter for the tip. The base of these relays is not your typical Auto config, in-as-much as the pins on the relay are recessed in the housing, and the housing slides onto a 'moisture 'proof' receptacle that has a rubber seal. Where-as the auto types, the pins are exposed and just plug into the board.
I would agree that Hella is a good brand. We'll have to see if one of the electronic gurus on here has found a higher amp-rating relay.
Thanks,
