89 351
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2673
Printed Date: November-23-2024 at 6:40am
Topic: 89 351
Posted By: duffnit
Subject: 89 351
Date Posted: November-02-2005 at 9:05am
When I purchased my 89 SN the PO said the engine was replaced with a short block 351.
Can someone explain the difference between short vs. long blocks, and how I could determine which one I have??... Thanks for any help.
------------- Danny
"no offense- but the rate at which you spread bad information is very impressive"
Posted By: GottaSki
Date Posted: November-02-2005 at 9:19am
Short means no heads. So it still has the original heads.
River Rat to Mole
Posted By: JoeinNY
Date Posted: November-02-2005 at 9:31am
A short block is a term for a replacement sub a**embly that does not include the Heads, a long block is an engine sub a**embly that includes the the short block plus Cylinder Heads and usually more.
They are not terms that describe the type of engine that you will end up with (like a small block vs. a big block), but rather how much of the engine was bought as new/rebuilt.
So you have have an engine with a rebuilt/replaced short block and with the original heads if the PO is to be believed. So the valves/springs may be tired but the cylinders/rings, main bearings, oil pump, connecting rods, etc should be tight and ready to go for a long time. Not all short blocks are created equal, both in terms of what parts they include and in quality of the work, hopefully you got a good marine unit...
1967 Mustang 302 "Decoy"
Posted By: duffnit
Date Posted: November-02-2005 at 12:22pm
Thanks for the info....
The boat runs great...A little over 46 on my GPS with a four blade prop... ...
I've heard those terms used over the years, just never knew. Now I do. Thanks again.....
------------- Danny
