Transmission swap ?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=26901
Printed Date: April-04-2025 at 1:46pm
Topic: Transmission swap ?
Posted By: zach1234
Subject: Transmission swap ?
Date Posted: July-10-2012 at 2:35am
i am working on a 1997 ski Nautique it has no reverse and no neutral any more. It has a 1.23/1 PCM transmission in it now. I have a 1/1 PCM transmission from a 1991 supra and the prop to match. Does anyone know if i can just swap the trans and the prop and run it tell i get the other one fixed thanks for the help. And yes i tried to call Eric today but i don't get off work tell 5 and they are closed.
Posted By: Gary S
Date Posted: July-10-2012 at 3:05am
I think that by the time you figure this all out,your rebuilt one would be back IMO.The PCM trans has an angled output shaft so the engine sits more level,I also believe it changes the rotation of the prop so the engine is a left rotation and the prop turns right. Others who know the newer boats will be able help in the morning.
Posted By: SNobsessed
Date Posted: July-10-2012 at 10:45am
Keep it original!
Posted By: 89Martinique
Date Posted: July-10-2012 at 12:11pm
the 1.23:1 has an angled output so the engine sits MORE level. they did this in late 80's as a PowerPlus package because it allowed the front cylinders to receive more fuel and the back cylinders less so its more balanced as they found when the engine is inline with the prop shaft the front tended to run lean while the back ran rich. The PCM 1:1 is an inline transmission. This will be a huge challenge if its even remotely possible as you would need engine mounts with big adjustment and you need to get every thing lined up perfectly or else it will fain in short time.
So it would be best to buy a new 1.23:1 or have it rebuilt.
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!)
1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus
1984 E-Scow
Keuka Lake,
Posted By: Jllogan
Date Posted: July-10-2012 at 12:21pm
Sounds like trouble to me. Sell the 1:1 and use the money to rebuild the 1.23:1
http://correctcraftfan.com/diaries/details.asp?ID=5792&sort=&pagenum=1" rel="nofollow - 1986 Ski Nautique 2001
Posted By: zach1234
Date Posted: July-10-2012 at 11:22pm
I guess I don't understand didn't some of the ski nautique come with a 1/1 transmission . did they have different motor mounts . or is it just a matter of realigning the engine .
Date Posted: July-10-2012 at 11:33pm
They did... And from what joe says, the mounts should work for both.
But I still agree with the above suggestion... By the time you buy a new prop and do a massive realignment, it would be cheaper and easier to rebuild the 1.23 and stick it back in. Not to mention the handling abnormalities caused by the lh prop nor the lesser holeshot of the 1:1.
Date Posted: July-10-2012 at 11:38pm
it depends on the year. the 1:1 transmission requires the engine and transmission to be in line with the prop shaft. when pcm made the 1.23:1 transmission they angled the output so the engine could sit almost level for a more efficient engine. they called this the "PowerPlus Package". many boats went straight to the PowerPlus package for more performance at not too much more cost.
Current Boats:
1984 E-Scow
Keuka Lake,
