1985 Nautique Wiring Harness Install
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2696
Printed Date: April-21-2025 at 2:15pm
Topic: 1985 Nautique Wiring Harness Install
Posted By: chavonbravo
Subject: 1985 Nautique Wiring Harness Install
Date Posted: November-07-2005 at 10:22am
Hey all, I'm probably buying a boat this weekend that doesn't have the wiring harness for the whole boat installed. It comes with the boat, I just gotta put it on. I've seen the wiring diagram for the dash in reference page and understand how to do all that. Everything else I'm sure is easy enough since it comes with the plugs and you just plug everything in. My question is this, since I've never even been on an inboard before, is if it's easy to install the harness, I mean...am I going to have to rip up the floor to get the wiring under it and into the dash? Or is it something I can do without tearing anything up?
Posted By: Bob's2001
Date Posted: November-07-2005 at 10:39am
Welcome! I have a SN 2001 and there is a big hose(tube) that the wiring runs through. It goes from under the dash to the engine compartment. I ran a wire for depth sounder with no problems. If you have an electricians snake or a stiff wire you should be able to pull the harness thru no prob.
------------- Bob Ed
83 2001
Date Posted: November-07-2005 at 10:57am
Thanx Bob, appreciate it. :)
