engine stalling
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2706
Printed Date: November-26-2024 at 11:06pm
Topic: engine stalling
Posted By: Tom Southwind
Subject: engine stalling
Date Posted: November-09-2005 at 9:12pm
I bought a 77 Southwind has a new engine it runs like a clock on fake lake. But after runing on lake for ten min. it stalls sounds to me like it loads up and dies. It will start back but will run for a min or less. Where would you startto look for the problem
Posted By: 64 Skier
Date Posted: November-10-2005 at 2:35am
Do the 10 minute run again without the flame arrestor and let us know what the choke is doing.
Does the engine rough idle for a few seconds before it dies or does it stop immediatley?
Does the new engine have a new coil and electronic ignition? Coils have been known to quit once warm.
64 Skier
66" HO VTX and 67" HO Triumph
http://www.correctcraftfan.com/diaries/details.asp?ID=1071&sort=&pagenum=3&yrstart=1971&yrend=1975 - 71CC
Posted By: David F
Date Posted: November-10-2005 at 7:25am
Does the new engine have a new coil and electronic ignition? Coils have been known to quit once warm.[/QUOTE]
Ditto for ballast resistors.
Date Posted: November-14-2005 at 5:04pm
the choke works fine the engine doesnot idle rough. It is not electronic ignition. What is a ballast resistor and where would that be
Posted By: JoeinNY
Date Posted: November-14-2005 at 6:04pm
A ballast resistor is basically a power resistor used to lower the voltage going to the ignition coil. The ignition coil is in some cases designed to run on about 10 volts instead of the 13 plus you see at the battery with a working charging system. It is designed to work at 10 volts so it can provide a spark during starting when the large current draw from the starter lowers the battery voltage significantly. Typically the ballast resistor is bypassed during cranking but in line with the coil during running conditions so the coil sees a consistant 10 volts (I am rounding for simplicity). It is typically a ceramic part located under the dashboard. This is a case where you can safely go to an auto parts store and buy a cheap part and not worry about it blowing up your boat. However I wouldn't necessarily be convinced that this is an ignition gremlin. It is possible to have enough crap floating around a fuel filter or in your float bowl of the carberator to produce these same effects, if the boat has sat for any amount of time lately I would look into the fuel system as well. Good luck.. -Joe.
http://www.correctcraftfan.com/diaries/details.asp?ID=1477 - 1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Posted By: Tim D
Date Posted: November-15-2005 at 9:55am
Check the timing. Maybe it's set too high and advancing itself after running a good distance for 10 minutes.
Tim D
Date Posted: November-15-2005 at 8:30pm
thanks the weather is going to put this off till next summer got to get the water out and antifreeze in
