Balancing Trailer Tires ?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27308
Printed Date: November-18-2024 at 7:30pm
Topic: Balancing Trailer Tires ?
Posted By: nautique frk
Subject: Balancing Trailer Tires ?
Date Posted: August-04-2012 at 2:01am
Can someone advise on the best practice on trailer tires.. To have balanced or not ? I am getting a new set of 14" 5 lug trailer wheels from local WM or Northern Tool. I know these are not balanced should I take them to a tire shop and have them balanced ?
Date Posted: August-04-2012 at 2:31am
Also curious on proper torque ft/lb for lug nuts ?
Posted By: Big t
Date Posted: August-04-2012 at 8:08pm
I balance the trailer tires on all my trailers even the little 4.80 x 8 they tow smother!! It might be over kill but That's me
Date Posted: August-04-2012 at 8:24pm
I agree - get them balanced. I was shocked to see how much it took to balance the 12" on my Tee Nee.
Date Posted: August-04-2012 at 9:44pm
I ended up getting them balanced thanks guys for the info !
Date Posted: August-06-2012 at 12:48pm
Pete do you know proper torque for lug nuts ?
Date Posted: August-06-2012 at 2:22pm
The SAE chart for a 1/2-20 says 565 inch pounds, Of course you could have asked at the place that balanced the tires but, they probably wouldn't be able to answer the question - we all know how they use the impact's!!!!
Posted By: quinner
Date Posted: August-06-2012 at 3:17pm
Pete, is that less then 50 ft-lbs?? Seems awfully low??
If the wheels are steel I would imagine 80-100 ft-lb, Aluminum would be less.
Had a set of Ronal alloy wheels on a vehicle that were very specific, learned the hard way after a Good Year store installed them incorrectly and a few hundred miles later on the highway while towing my boat the truck was wobbling/wandering, pulled over to find studs missing and one wheel down to (2) lug nuts. Lucky for me they had "torqued to 120" right on the invoice, which was wrong, and they picked up the tab on tow bill and repairs including 4 new wheels.
Posted By: kytom2
Date Posted: August-06-2012 at 4:51pm
565 divided by 12 = 47 ft/lbs.
Posted By: GlassSeeker
Date Posted: August-06-2012 at 7:06pm
torque them as hard as you can by hand...then when you get a flat you can get them off. I've never had a wheel fall off or lug nuts loosen up.
------------- This is the life
Date Posted: August-06-2012 at 7:40pm
All I did was quote SAE specs. If you want to go more that's up to you.
Chris, The 50 lbs is easy for you but that's just under half of my body weight!! tougher for me!!!
Posted By: MattB
Date Posted: August-07-2012 at 9:44am
The PO had torqued mine up to an inch of thier life, combine this with dumping in and out of the water when I came to remove the wheels to rivet the fenders back on I broke 3 sockets and had to use a 6ft bar to get the buggers undone, If this had happened on the road it would have been a total nightmare. I greased up the nuts and went with 60 ft/lbs.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=6102" rel="nofollow - 2001
http://uksn2001.blogspot.com/" rel="nofollow - SN2001 Blog
Date Posted: August-08-2012 at 7:37pm
