riser torque
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27413
Printed Date: May-19-2024 at 7:31pm
Topic: riser torque
Posted By: john beck
Subject: riser torque
Date Posted: August-11-2012 at 2:23pm
Help. I'm trying to find the torque spec. for 1992 PCM 351 riser bolts to exhaust manifold. Also, do I need to put any gausket sealer on the new gausket? Thanks
Date Posted: August-11-2012 at 3:50pm
John, Welcome to CCfan. SAE torque specs of bolts are available on line. Are you putting SS bolts back in? It makes a difference.
OK, when it comes down to gasket compounds, I'm very old school. I do not like RTV's and always use Permatex non hardening. No matter what you use, the key to a good seal will be the mating surfaces MUST be flat and smooth. If not, they may even need a dust cut on the mill?
Date Posted: August-12-2012 at 12:08am
Thanks Pbrainard. I tried google sites looking for torque on the riser. What website would you recommend? Thanks again.
Date Posted: August-12-2012 at 7:32am
John, Google "SAE bolt torque". Also, you never said if you are using SS bolts. It's a good idea plus I recommend anti seize but understand that using it will alter your torque.
Posted By: kapla
Date Posted: August-13-2012 at 12:43am
Definetely you want the mating surfaces to be REAL FLAT!... any rust in the surface is a potencial leak point.... I speak from personal experience...new gaskets, cleaned the surface and assembled, hundred of hours later, found water in cylinder...it was the manifold leaking.... A head gasket and a trip to the machine shop, got me again in the water. Definetley go SS bolts!..also replace the allen ones that hooks the lower manifold to the head...
