WTB 1" Sherwood Sea Strainer
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27465
Printed Date: November-17-2024 at 9:20pm
Topic: WTB 1" Sherwood Sea Strainer
Posted By: M3Fan
Subject: WTB 1" Sherwood Sea Strainer
Date Posted: August-14-2012 at 8:32pm
Or equivalent, if anyone has one lying around.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Date Posted: August-15-2012 at 10:10am
Joel,
If you don't have any luck finding one, http://www.mcmaster.com/#standard-strainers/=iuwd4h" rel="nofollow - the 1" size is $29.00 at McMaster Go down the page to "Nylon T strainers"
Posted By: OverMyHead
Date Posted: August-15-2012 at 11:19am
I found mine at Granger.
1987 Ski Nautique
Posted By: M3Fan
Date Posted: August-15-2012 at 12:49pm
Pete- what mesh do I want?
Edit- forget it- I went with 50.
Date Posted: August-15-2012 at 11:06pm
Joel,
Is the strainer for the new S&S or a replacement for the SN? If I had to take a shot at it, you want it for the new boat. How bad is the water it's going to be in? FYI, up north, the water is so clean, a strainer really isn't needed. I have none on any of my boats and have never had a problem.
Posted By: M3Fan
Date Posted: August-23-2012 at 1:25pm
This is for the new boat. I went with the 50 mesh and it looks pretty small. Definitely smaller than the mesh on the Sherwood version. Probably not a problem up north (where the boat will reside) however around here I'll have to keep an eye on it I suppose. Even after 1 outing on a local lake, I had a decent amount of crap in the trans cooler input screen. Not enough to affect temps, but surprising none the less hence the prompt to get the strainer.
Date Posted: August-23-2012 at 10:12pm
Joel,
If the 50 plugs up too quick, just order the 20. A 20x20 is still pretty fine.
Posted By: M3Fan
Date Posted: August-23-2012 at 10:44pm
Joel,
UGH. Just ordered the 80, figuring bigger had to be bigger. DAMMIT.
Date Posted: August-24-2012 at 8:35am
Joel,
Mesh is the number of holes per square inch. With only 20 instead of 80, the holes are bigger. Next time your over at McMaster, take a look at one of their explanation pages. In this case, search "wire mesh" then click on "about".
Posted By: M3Fan
Date Posted: August-24-2012 at 11:25am
May as well order the 20 and have the whole collection! I can change the strainer based on dissolved solids in the particular water I'm skiing, LOL.
Posted By: M3Fan
Date Posted: August-27-2012 at 1:22pm
Just an update in case anybody looks this up in the future: the 50 mesh is fine. After two days in the nastiest water you could possibly test a strainer in- milfoil/shallow water/muck central, it was fine. The smaller mesh filters out a surprising amount of silty minutia that I can't believe would previously circulate through the engine, FWIW, but it did not get anywhere NEAR full or clogged or even close the whole weekend. Really happy with the 50 mesh.
