Transmission Noise
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27585
Printed Date: November-18-2024 at 6:40pm
Topic: Transmission Noise
Posted By: slalom1
Subject: Transmission Noise
Date Posted: August-24-2012 at 1:37pm
I have a 1998 ski nautique with approx. 360 hrs on it. When the motor is cold and you drop it into gear I hear a grinding sound coming from the transmission. It goes away when it warms up. The fluid level is correct per the manuel with approx. 2 quarts of Dexron III and the there is no vibration. It runs and shifts perfect. I'm trying to pin point the problem. Does anyone have any suggestions?
Posted By: kapla
Date Posted: August-24-2012 at 2:48pm
If in fact you hear grindind sound, check the fluid and look for metal shavings.
Posted By: slalom1
Date Posted: August-27-2012 at 9:31am
Thanks. Already checked for that and there are no metal shavings. I guess I'm just going to have to keep investigating.
Posted By: SNobsessed
Date Posted: August-27-2012 at 10:36am
Could it be a bad damper plate?
Date Posted: August-27-2012 at 11:22am
N.G., I agree with Chris so do check the damper. Also, when was the last time you aligned the shaft to the strut and engine. If misaligned and run for some time, it will tear up the trans.
Metal shavings have a tendency to collect at the bottom of the case so you may or may not see anything via the dip stick.
Posted By: slalom1
Date Posted: August-28-2012 at 9:27am
Prop shaft has never been out of the boat. I will check the damper plate to see if everything is aligned.
Date Posted: August-28-2012 at 9:31am
slalom1 wrote:
Prop shaft has never been out of the boat. | This doesn't matter. Again, when was the last time you aligned the shaft to the strut and engine? Do check it.
