Gelling,sanding and polishing
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27690
Printed Date: November-18-2024 at 6:45pm
Topic: Gelling,sanding and polishing
Posted By: Gary S
Subject: Gelling,sanding and polishing
Date Posted: August-31-2012 at 11:23pm
Been busting my butt trying to get this thing done so I can
at least try it out before I have to put it away for the
year. I had waited too late last year and had trouble with
the gel taking so long to set up when cool out,so I started
when it was good and HOT. Very nerve racking and was worried
that something would go wrong.Had in the past alot of trouble
with bugs liking the fresh gel and was prepared this time. I
think it turned out pretty good but need to see how it looks
when it's outside. A big thanks to Tim Morfoot for some tips
In the end everything went fine,I think I'm ready for
that theft recovery boat with the side cut out!
This is what I started with,a big hole where the control
mounted!
part way thru
done-
Posted By: nautique frk
Date Posted: September-01-2012 at 1:36am
Looks good !!
Posted By: pepatrick
Date Posted: September-01-2012 at 2:38am
Wow...what is the secret. I have a few areas that will need to be touched up once I get it wet sanded. You cant even see where the hole was in yours...Great job!!
Posted By: gR@HaM
Date Posted: September-01-2012 at 6:48am
Nice job I've just had to do something very similar with the dash where PO had cut a hole for a large switch panel.
Possibly a stupid question, what are you doing with the throttle control??
'82 Ski Tique
Date Posted: September-01-2012 at 9:12am
Gary,
Nice!
Graham,
Gary has the SS center console with the throttle and shift controls going in the boat.
Posted By: Riley
Date Posted: September-01-2012 at 9:57am
Gary, nice job! I'll have to get some pointers from
you as we've got a radio hole to fill.
Date Posted: September-01-2012 at 10:01am
Gary,
You're going to need some new aluminum "J" molding. McMaster has it as well as the countersunk head Pop rivets.
Posted By: dwcar
Date Posted: September-01-2012 at 10:03am
Nice work Gary!
83Ski
Posted By: reftech
Date Posted: September-01-2012 at 10:46am
Very nice job! Well done!
Posted By: SNobsessed
Date Posted: September-01-2012 at 12:10pm
Gary - Looks great!
Imagine paying a hourly rate to do such fine detail!
Posted By: Gary S
Date Posted: September-01-2012 at 3:23pm
Thanks for the encouragement guy's. I've missed alot of great
boating weather this year and knew I would,but I think it's
important to get this thing back together as intended.
The hardest part of the project,to me anyway,is color matching,
especially on a 43 year old! When I had started to repair chips,
and holes I had ordered a stock quart of an Ivory from Mini Craft.
It was not close enough so I cut out a piece out from behind
the back seat and sent it in for a color match. Still was not good
but by combining the two in a ratio I have figured out and writen
down so I would not forget,it works for me. If I look close and
because I know where to look,I can find them,but I'm not going to
let anyone get that close I call it my 20 ft Mustang .
The main key here and one that may not seem right,is you have
to make the area you are repairing bigger. Grinding a bevel
out from the damage solves that,it gives the mat and resin
something to bond to.If you don't do this and just try to butt
the new layers to the old,it will crack.It also in my case could
crack where those 90 degree cuts come together,so they needed
to be ground to a radius.After I did that I cut out a cardboard
template of the hole and used that to cut a piece of glass I
had to fit.I don't even know what it is called but it was a
layer of mat bonded to a layer of 1/4" woven cloth. I resined
it and let it set up and then ground to fit the bottom of the
repair.After bonding it in,I then cut a piece of mat big enough
to go over the whole backside of the hole plus about 1/2" over
the old glass after sanding and wiping clean with acetone.Then
on the outside just started adding layers of larger cutouts
of matt,each time going further out on the bevel I had ground
earlier. Here are a few more pictures I took.I also tried to
brush on the gel to get the build up I needed because I was
worried that I would run out of the matched gel I have. When
you spray it you waste more because the gun and cup are so
large. The final coat was sprayed ,I added Dura Tec clear to the
mix at half of what is recommended,because to me 50/50 makes
it too thin especially on a vertical surface.
After a day I started by hand sanding. I had found out during
they layup that the panel while looking flat is actually got
a compound curve to it and I had to be careful not to sand
thru.Had a small sag to remove so I started there with 600.
I had overlapped the repair with gel by about 9" and so
started sanding overall with 800 followed by 1000 and 2000
to blend it in. Finished up with 3M 05973 compound with
a white foam pad.
Pete thanks to you I always use McMaster Carr now even for sand
paper. Already got the rivits from them but for the aluminium
trim I went with original trim from my supplier
in Sterling Illinois who unselfishly helped me with a floor,
bucket seat with hardware and the trim from that Mustang he
parted. Thanks Steve! Here are some more pictures and one
tease of the trial fitting.
Posted By: MartyMabe
Date Posted: September-02-2012 at 2:34pm
And I'm getting ready to 'Cut' holes in the 93 Gary!! Gonna install the wired remote in the transom for the radio. Also gonna cut cup holders in the gunnels for the rear seat area. I'm getting rid of those plastic fold down cup holders at the bottom of the back seat near the floor.
66 Skylark
http://www.correctcraftfan.com/diaries/details.asp?ID=5041" rel="nofollow - 93 SN
If you're not living in NC, you're just camping out!
Date Posted: September-02-2012 at 6:11pm
Marty,
Cutting holes non original??
Posted By: DrStevens
Date Posted: September-02-2012 at 7:20pm
Gary, it looks great!
Date Posted: September-02-2012 at 9:01pm
Gary,
Did I miss something? Where did you get the glass sole pan?
Posted By: Gary S
Date Posted: September-02-2012 at 9:49pm
I also must thank these others, Johnb for the battery tray from his departed SS and who also let me copy his side panels,The Godfather, Dave Hendricks for the "Mustang" emblem for the console and to Bruce for the heads up
The next step is the interior and not having any pictures of the original,I leaning toward a cream,to match the deck,motorbox so it looks like a 'glass one and then the rest like Rodneys. What do you think?
