lift points
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27731
Printed Date: November-18-2024 at 5:39pm
Topic: lift points
Posted By: forvicjr
Subject: lift points
Date Posted: September-05-2012 at 12:43am
Anchor or lift rings front and rear. Anyone had the metal that they are bolted to rust out? Whats the best repair?
Posted By: 74Wind
Date Posted: September-05-2012 at 12:49am
Salt water boat? Model? Year?
------------- 1974 Southwind 18 1975 Century Mark II
Posted By: forvicjr
Date Posted: September-05-2012 at 1:20am
Local freshwater ski tique. Im the fourth owner 1000 hours, 1981. It looks like salt but I know the boat and its never seen the ocean. Although when not stored inside, it was covered under an open sided shed. Moisture trapped under cover maybe? This thing was rarely used.
Posted By: Waterdog
Date Posted: September-05-2012 at 9:59am
Find a boat thats being parted out in the Boat Parts Section. Buy good used lift rings THEN cut the old ones out and replace them. Check/replace & reglass the plywood doublers too.
------------- - waterdog -
Posted By: forvicjr
Date Posted: September-05-2012 at 11:28am
how do you access the front. its not as bad but still needs replaced. I barely got in the nose far enough to discover the problem.
Date Posted: October-04-2012 at 9:53am
CC is notorious for not using the best materials out there for corrosion resistance. What part is actually rusted and how bad is it? Pictures would be great. I would not go with an OEM part from someone who is parting out a hull. I'd be fabricating or having the part fabricated out of stainless. If it is the bracket that is glassed in, then there will be glass work done. On the aft, I'd also worry about the wood that's glassed in for the anchoring. We have seen some pretty rotten wood in previous threads. Once again, the search feature is a fantastic tool!!
Posted By: forvicjr
Date Posted: October-04-2012 at 11:41am
8122pbrainard wrote:
CC is notorious for not using the best materials out there for corrosion resistance. What part is actually rusted and how bad is it? Pictures would be great. I would not go with an OEM part from someone who is parting out a hull. I'd be fabricating or having the part fabricated out of stainless. If it is the bracket that is glassed in, then there will be glass work done. On the aft, I'd also worry about the wood that's glassed in for the anchoring. We have seen some pretty rotten wood in previous threads. Once again, the search feature is a fantastic tool!! |
Thats whats weird, I've poked around and the wood is ok. It looks to me that the rust its just from moisture being trapped. The wood is bright showing no water damage. The angle though is so brittle that you can grab chunks of it and break it off. The angle isnt coated in any way and the bolts are rusted out too. Are the bolts glassed in or are they replaceable without much trouble.? Ill try to get in there for some picks.
Date Posted: October-04-2012 at 1:04pm
Vic, Yes the bolts are glassed into a wood backer bedded into the glass.
Once again, the search feature is a fantastic tool!! | If you take the time, you WILL see pictures!!!
Posted By: forvicjr
Date Posted: October-04-2012 at 2:49pm
I think the search didnt like my key words. Because I came up with nothing. I'll try again....
Posted By: forvicjr
Date Posted: October-04-2012 at 10:25pm
Well I. Guess the lift eyes will be repaired when stringer replacement is needed. As they will be hell to get to untill the thing is stripped completely down.
