rubber motor mount
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27825
Printed Date: November-17-2024 at 9:57pm
Topic: rubber motor mount
Posted By: thateb
Subject: rubber motor mount
Date Posted: September-15-2012 at 9:06pm
I searched the forums and didnt find any info so Im posting.
I need the rubber "hose" part for the rear mount on a Ski Tique. It is 5/8" ID, 1-1/8" OD.
Ben
Date Posted: September-15-2012 at 10:13pm
Ben,
Be a little more descriptive on the part needed. Is this the rubber bushing on the engine mount? If so, why only one and not all four? Have you ever checked the alignment??
If you replace all four, rubber bushings can be had at McMaster.
Date Posted: September-16-2012 at 10:14am
Ben,
http://bpi.ebasicpower.com/c/ENGMTS/Engine+Mounts" rel="nofollow - Here's a link to some bushings. They are down the page about 1/4 of the way. See if they match up to what you need.
BTW, I see you were on site this morning. Nothing to add regarding your specific needs? What about that alignment? I asked since if out, it could put more pressure on one of the mounts.
Posted By: gR@HaM
Date Posted: September-16-2012 at 3:53pm
Interesting, sorry for the thread-jack but could misalignment be the reason my tique has a broken transmission mount?
'82 Ski Tique
Posted By: thateb
Date Posted: September-16-2012 at 5:45pm
I didnt mention that the shaft is not bolted up to the output shaft. I am still in the process of getting the engine going with the new camshaft. Im just about ready to start it. Yes the rubber bushing on the left rear mount is missing which throws off the alignment which I will be tackling soon. I didnt see anything on that website that resembled the bushing. It is quite basically a rubber tube that is .625" ID, 1.125" OD. I dont recall how long. Maybe an inch or inch and a half. I will take a closer look at the rest of the bushings when I get out to the boat today and report back.
-Ben
Date Posted: September-16-2012 at 6:21pm
Graham,
The possibilities are high but I'd say the bad condition of your stringers are a likely better cause of the broken mount.
Posted By: thateb
Date Posted: September-16-2012 at 11:41pm
This is the rubber bushing Im looking for. 0.625" ID, 1.125" OD, maybe 1" long. Also found out my starter is bad.
Posted By: dwcar
Date Posted: September-17-2012 at 11:23am
http://www.skidim.com/prodinfo.asp?number=R094004" rel="nofollow - rear bushing
83Ski
Posted By: thateb
Date Posted: September-18-2012 at 3:41pm
Thanks btw. Thats exactly what Im looking for.
Posted By: gR@HaM
Date Posted: September-18-2012 at 6:25pm
Graham,
Thanks Pete, although not the answer I was hoping for!
I was under the impression that as I had no damage to the exterior gelcoat on either engine side, it's mounted on a cradle and the cradle bolts are still 'grabbing' to the stringers, I should be ok for a full season on the water next year before tackling a stringer replacement job.
By the sound of things now I'm not so sure
'82 Ski Tique
Posted By: gR@HaM
Date Posted: September-18-2012 at 6:28pm
Ben, again, sorry for jumping in on your thread
'82 Ski Tique
Posted By: thateb
Date Posted: September-19-2012 at 12:11am
No problem! best of luck
