Connecting water hose
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=28032
Printed Date: November-18-2024 at 4:51pm
Topic: Connecting water hose
Posted By: dstop
Subject: Connecting water hose
Date Posted: October-09-2012 at 11:08am
I'm doing an out of the water oil change, in the Manuel it says I should run the engine with a hose hooked up to it. Does any one have a video or a exact instruction how to hook up the water hose to the engine? It's a sn95 also why does everyone say not to use a farm oil filter,    I have been using syntec synthetic oil for the last 2 seasons the only oil filter for synthetic oil I could find here is a farm filter
Posted By: Jllogan
Date Posted: October-09-2012 at 12:05pm
many articles/opinions against fram, basically substandard materials.
Hose hookup there are several options. A device called fake a lake, looks like a plunger and goes on the raw water intake on the bottom of the boat. You can unhook your first water intake hose from the hull, the one behind the strainer and shove the hose inside and tighten a hose clamp (my one friend does it this way). Also several of us have rigged up a T in the line with some garden hose fittings for easy hose on and off, this is what i have. I think TRBENJ and a few others have documented on the site. Basically a T with a shutoff valve and a threaded adapter for a hose to thread on.
http://correctcraftfan.com/diaries/details.asp?ID=5792&sort=&pagenum=1" rel="nofollow - 1986 Ski Nautique 2001
Posted By: dstop
Date Posted: October-09-2012 at 12:13pm
Yes the T junction sounds like a good idea. Do you have any pictures of that setup ?
Posted By: Jllogan
Date Posted: October-09-2012 at 12:33pm
Posted By: quinner
Date Posted: October-09-2012 at 5:33pm
Another method is to simply put your intake hose into a 5 gallon bucket filled with water, place garden hose in same bucket, run hose and motor simultaneously.
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
Posted By: SNobsessed
Date Posted: October-09-2012 at 9:19pm
Wix or Napa filters are good ones. I have never heard of a specialty filter for synthetic oil - sounds like an active marketing buzz to me.
Date Posted: October-09-2012 at 9:40pm
From Fram did you expect anything different?
Posted By: 80SN Barnfind
Date Posted: October-10-2012 at 11:07am
Another method which I installed on my 80SN:
Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
Posted By: hein
Date Posted: October-12-2012 at 2:28pm
Thanks for that picture. I think its a brilliant idea,and i am also going to do that on my boat!
A bad day skiing is better than a good day at work.
Date Posted: October-12-2012 at 8:28pm
Noel,
It's looks like you reduced the pipe size to get the fittings in. If so, it's not a good idea especially in a suction side application.
EDIT: Noel, after a second look, it looks like you did it correctly with the pipe size!
Posted By: hein
Date Posted: October-12-2012 at 9:11pm
Jllogan,That looks like quite a different manifold setup. Stainless steel?
Date Posted: October-12-2012 at 9:42pm
Hein,
That's not Justin's boat. He just posted the picture. The stainless are Tim's stainless dual exhaust pipe conversion and not the manifolds.
Date Posted: October-12-2012 at 10:01pm
Hein,
Here's Tim's complete thread on his dual conversion:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=6888&KW=got+pipes&title=got-pipes" rel="nofollow - Got pipes
