trailer identification
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=28734
Printed Date: November-24-2024 at 10:53pm
Topic: trailer identification
Posted By: jcamp72
Subject: trailer identification
Date Posted: January-14-2013 at 3:58pm
I'm sure somebody has talked about this in the past but couldent find any definite info on it. Can you tell what number and year a trailer is by the id number stamped on the trailer? I'm pretty sure I have a number 3 but wanted to be sure.
Date Posted: January-14-2013 at 4:02pm
Maybe. If its old enough to have a metal ID plate riveted to it, then the model number may be part of the id. I believe my #2 reads 2-xxxx.
The best way to be 100% sure is to post a picture. That along with a few basic dimensions will allow us to tell you which youve got.
Posted By: jcamp72
Date Posted: January-14-2013 at 4:20pm
Posted By: jcamp72
Date Posted: January-14-2013 at 4:22pm
its way big for my 70 cuda probably only have about an inch on outside of bunks.
Posted By: JoeinNY
Date Posted: January-14-2013 at 4:26pm
someone will be able to be more specific but it is a trailer from a mid eighties 2001 model ski nautique.
http://www.correctcraftfan.com/diaries/details.asp?ID=1477 - 1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Ahh, I forgot you were Morfoot's neighbor. I remember seeing that boat when you were considering buying it.
That is a '84-87 #3 delux trailer ('88 was the same but had surge brakes as standard equipment). Its meant for a 2001 Ski Nautique hull, which is just shy of 19'. Yes, it is too big for your 'Cuda, which really needs an older #3, meant for a 17-18' hull.
Posted By: jcamp72
Date Posted: January-14-2013 at 4:30pm
TRB
does your #2 have a bow stop like the one in my pictures?
Posted By: jcamp72
Date Posted: January-14-2013 at 4:33pm
the reason i asked earlier about the stamped numbers i because the last two are 88 and i figured that was real close to the correct time period.
Posted By: Hollywood
Date Posted: January-14-2013 at 4:38pm
Are the insides of the fenders open or closed off? 5 or 6 lug wheels?
Date Posted: January-14-2013 at 4:39pm
Close, but not quite... see my post above. I believe brakes were standard in '88, and yours doesnt have them. Ive definitely seen some '87's without brakes. First year for the 2001 delux may have been mid-83, but all trailers were like that starting in '84. I believe CC may have gone from 5-lug 14" rims to 6-lug 15" wheels in '86.
Most of my #2's and #3's are from the '68-80 vintage and have the lower bow stop. Our '79 #4 has the same type of stop as yours.
Posted By: jcamp72
Date Posted: January-14-2013 at 4:45pm
so does this one look like a #2 or early #3?
Posted By: jcamp72
Date Posted: January-14-2013 at 4:46pm
5 lug wheels and the inside of fenders is closed off.
Posted By: jcamp72
Date Posted: January-14-2013 at 4:51pm
well i was right about the wheels but i just took a closer look at the fenders and they are open.
Date Posted: January-14-2013 at 5:04pm
That would make your blue trailer somewhere in the 1983.5-1985 range.
That white trailer is a #3 from the late 60's or early 70's... so exactly what you need for your Cuda.
Posted By: jcamp72
Date Posted: January-14-2013 at 5:15pm
Awesome thanks for all the help.
Posted By: Morfoot
Date Posted: January-14-2013 at 7:27pm
Jbear drug the #3 up from Orlando this summer to help him out. Too bad Uncle Todd didn't need a #3 trailer as Lanier is an hour north and Jonathan could get the the boat on its proper trailer.
Date Posted: January-14-2013 at 7:33pm
Ha, Im totally out of the loop on this one... no idea whats going on.
Date Posted: January-14-2013 at 7:51pm
Tim, somebody towed that trailer from somewhere and someone else needs another trailer from somewhere else.
Tim, did I get that right?
Posted By: Morfoot
Date Posted: January-14-2013 at 9:40pm
Yes sir you did... Someone is always needing something somewhere, and there is always somebody here that will step up for someone else!
Posted By: cphase
Date Posted: January-14-2013 at 9:48pm
Like a prop puller...
Thanks,
Jeff
http://www.correctcraftfan.com/diaries/details.asp?ID=6549" rel="nofollow - 82 SN
http://www.archlinux.org" rel="nofollow - Arch Linux
