Cutlass Replacement
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=29364
Printed Date: June-02-2024 at 9:07am
Topic: Cutlass Replacement
Posted By: flipflop
Subject: Cutlass Replacement
Date Posted: March-30-2013 at 10:28pm
I decided to replace the cutlass bearing because I had some down time and windy weather. Boat is a 99 SAN with ~700 hours. The prop shaft had visible up and down movement with an audible clunk in the strut. I attached a picture of the old one. The bushing on the right was in the front and noticeably worn. You can see where there were a few pieces missing around the circumference. The rear, one on the left, didn't seem too worn.
Date Posted: March-30-2013 at 10:48pm
flipflop wrote:
The bushing on the right was in the front and noticeably worn. The rear, one on the left, didn't seem too worn. | James, You have an alignment problem.
Posted By: TX Foilhead
Date Posted: March-30-2013 at 11:50pm
The good news is the vdrive is pretty easy to take off now that your this far along. It's about 6 bolts and it slides right off, if you have something to lift it with there is a place to attach a ring on top, it weighs about 80 or 90 lbs I would guess from carrying mine around.
