Steering Cable replacement
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=29953
Printed Date: November-18-2024 at 7:44am
Topic: Steering Cable replacement
Posted By: W.U.S.S.
Subject: Steering Cable replacement
Date Posted: May-22-2013 at 2:31pm
I need help.
I have a 93 SN and need to replace my steering cable. I am fairly mechanical and have the rear floor and gas tank out of the boat.
I really do not know where to go from here.
I have been told to tie a rope to the end of the cable and pull, but I have not even gotten to the part where I disassemble the cable. I am not sure what stays or what goes.
I also need to replace the packing in my drive shaft.
I called a local dealer, and they cant get to it until the middle of June. Not an option.
Posted By: GlassSeeker
Date Posted: May-22-2013 at 3:04pm
"fairly mechanical" can figure this out with some searching of this site, and looking at the cable ends...it's not rocket science.
This is the life
Posted By: SNobsessed
Date Posted: May-22-2013 at 3:12pm
Lot of posts & pictures on the site about both of these.   Look at where the ends go, unhook & replace.
Posted By: storm34
Who is the local dealer?
Give Zach@N3 Boatworks a call and I'm sure he can walk you through the process.
Posted By: jbach
Date Posted: May-22-2013 at 5:30pm
i just did this, a week or so ago, mind you, it was on a v-drive. should be very similar to your direct drive.
-remove rear seat
-mark where steering cable is positioned in clamp bracket so everything will be the same going back in.
-unbolt steering cable from rudder arm
-unbolt clamp block that is 12 inches in front of rudder
-cut all zip ties around holding steering cable (mostly in ski locker)
-remove kick panel under driver seat
-i cut rudder end of steering cable off to remove the metal shaft that was connected to the rudder arm so it would pull through easier.
-unbolt steering cable "box" from steering wheel gear (4 bolts)
-pull cable from helm towards rear of boat, sometimes you may also need to push the trailing part cable towards the front of the boat.
-once i got the bitter end of the cut cable into the ski locker, i connected a wire to make sure i could pull the new one back through if needed. (didn't end up needing to do that. i remoced the kick panel instead
-i routed the new cable down through the floor fore/behind of the removed kick panel, through the ski locker and on TOP of the gas tank hold down brackets for easier replacement next time. (does not apply to direct drive)
-replace clamp bracket on marked position, re-bolt rudder arm.
-i needed to re-center steering wheel prior to the replacement, so i did and then installed the steering cable "box" at the helm.
-i installed an automatic bilge pump to keep the water out of the new steering cable.
not a bad job, it's easier on some boats than others. i already had everything removed doing some other work, once you have that it's literally a 30 minute job. would probably take me a couple hours from start to finish.
Posted By: W.U.S.S.
Date Posted: May-23-2013 at 1:41pm
Thanks JBach, almost exactly how you explained. Piece of cake!
I also need to redo my packing, I assume it just wraps around the treads? How tight does it need to be?
Posted By: storm34
Date Posted: May-23-2013 at 2:06pm
Rudder or Shaft?
Posted By: W.U.S.S.
Date Posted: May-23-2013 at 3:02pm
Drive shaft
Posted By: Jeff N
Date Posted: May-24-2013 at 10:46am
Fairly Mechanical,
I have an 89 2001 and am trying to learn more about the mechanics of these boats.   What symtoms did your boat have that caused you to conclude that the steering cable needed to be replaced?
Thanks,
Jeff N
Jeff N
05 - 206
89 - 2001
Posted By: W.U.S.S.
Date Posted: May-24-2013 at 11:00am
This is actually my second cable in 4 years. It was very difficult to steer, especially at slow speeds. Then when it set all winter, it wouldn't move at all.
After some research (alot if beer), my bilge seemed to be running a lot. I could not figure out where it was coming from, I pulled my access cover off and discovered my packing was leaking too much. I tried to tighten it, but it was still leaking.
I was told that it is supposed to drip about 1 time every 30 seconds or so. I think I had so much water in the back of the boat, my steering cable we under water causing it to corrode.
Hopefully replacing my drive shaft will solve this problem.
Until now, I only had outboards, so it is has been an exciting learning curve, but well worth it.
Date Posted: May-24-2013 at 3:35pm
What is wrong with the shaft?    Is it worn where the packing is?    If so, some guys have moved the stuffing box to a clean place on shaft, doesn't have to move much.
Posted By: Jeff N
Date Posted: May-25-2013 at 10:50am
Thanks. So as far as you guys understand, there are no "routine" maintenance aspects to the steering cable on these boats (i.e. if it seems to be working properly, then leave it alone)??
Jeff N
05 - 206
89 - 2001
Date Posted: May-25-2013 at 1:57pm
You are correct, Sir.
This is the life
Posted By: W.U.S.S.
Date Posted: May-29-2013 at 10:26am
Ok I am tying to assemble my packing nut. How much packing should go in? And how tight should it be? Maybe it is just me but it seems like it's not going to go, I was told I need at least three reps of packing but it seems like it is way too tight.
Posted By: storm34
Date Posted: May-29-2013 at 12:03pm
How many did you take out?
The rudder packing on the 01 Ski was pretty bad but I was able to replace what I took out and it was just fine.
Date Posted: May-29-2013 at 4:57pm
You could take 1 wrap out, get it started & compressed, then add the last wrap later.
Posted By: Gary S
Date Posted: May-29-2013 at 5:15pm
If your having that much trouble did you change the seal at the end of the support tube? Not easy to find,I called them and got the part number. After 40 some years and a new cable I didn't want to take a chance. It's Teleflex part number SA 37868P. Got mine http://www.fisheriessupply.com/teleflex-marine-tfx-sa37868p-sa37868p" rel="nofollow - here
