Trans fluid leaking
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=30011
Printed Date: November-18-2024 at 7:27am
Topic: Trans fluid leaking
Posted By: N2Deep
Subject: Trans fluid leaking
Date Posted: May-28-2013 at 3:52am
Got the oil/filter changed today and did a little maintenance but noticed I have a leak from the bolt on the shifter linkage. Anybody know if there is a seal there than needs replaced? Didn't take it off yet and thought I would ask here first. Cleaned up and restarted to make sure that is where it is coming from - so no leak in the pic.
------------- 1991 SN pulled by a 2010 Tundra
Posted By: eric lavine
Date Posted: May-28-2013 at 8:29am
it is an o-ring, not a lip type seal, ski-dim I believe carries them
Posted By: N2Deep
Date Posted: May-31-2013 at 2:10pm
Thanks Eric - got one ordered along with a few other needed items. Trying to get all the little things cleaned up.
