Can the spacer stay under the wedge plate
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3029
Printed Date: November-23-2024 at 6:38am
Topic: Can the spacer stay under the wedge plate
Posted By: Morto
Subject: Can the spacer stay under the wedge plate
Date Posted: February-13-2006 at 7:01am
Some guys are talking about losing some of the high rise effect by taking the spacer out and putting the wedge on. In my '82 Ski Tique do I have enough room to mount the wedge plate on top of the spacer? Is this sane? What angle is right for this boat? (I was sold a 15 degree plate in Oz and it looks too steep). I searched a lot of wedge plate topics but couldn't find an exact answer. Cheers all!
Posted By: Tim D
Date Posted: February-13-2006 at 7:17am
Does the wedge have a place for the pcv hose?
Tim D
Posted By: Morto
Date Posted: February-13-2006 at 7:21am
No Tim, in fact I'll be replacing the wedge plate with a more suitable angled one but in any case I figured it would be better to have the longest intake runners we can fit under the dogbox. What say you?
Posted By: skyhawkflyer
Date Posted: February-13-2006 at 7:31am
I've only seen one or the other installed. Having said that I'm sure someone will chime in who has both installed. If you have a spacer installed, and then install a wedge plate then chances are you'll have to change the rear float level to accomodate the change in angle. To check clearance stick a lump of clay on top your spark arrestor and then close the cowl.
Posted By: Morto
Date Posted: February-13-2006 at 7:36am
OK, can anyone see any reason why they shouldn't go on together if there's room?
Posted By: martini
Date Posted: February-13-2006 at 8:26am
I have installed and used both a wedgeplate and the original spacer on these engines with no problems on customers boats. You place the spacer in it's orginal location and place the "
wedge" on top of the spacer, followed by the carb.
Posted By: JoeinNY
Date Posted: February-13-2006 at 8:30am
If it fits it shouldn't hurt, the PO ran mine that way, but he also had changed the way the engine box was mounted so it was farther up from the floor level so I don't if it would have fit originally. I removed mine extra spacer and just put the wedge on when I put on the edelbrock intake because I don't want it to hit when I redo the engine box mounts, and my spacer was uglier than I wanted on my newly rebuilt engine.
-Joe.
http://www.correctcraftfan.com/diaries/details.asp?ID=1477 - 1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Posted By: GottaSki
Date Posted: February-13-2006 at 9:09am
I understand wedges come in 7.5 and 15 degrees.
A $1 can of Play-Dough can tell you how much clearance you have available.
River Rat to Mole
Posted By: Tim D
Date Posted: February-13-2006 at 11:12am
Raise the dogbox. Attach a 2x4's to the floor where the box & hinges touch the floor and cover them with carpet.
Tim D
Posted By: 66polyhead
Date Posted: February-17-2006 at 6:58pm
A typical inboard Is about 7 degrees. mine has a 7 deg. cheese wedge factory with a carter AFB. It makes a nice level surface, except coming on plane. You can always cut a hole in the top, and add a snorkle!
http://www.correctcraftfan.com/diaries/details.asp?ID=220&yrstart=1925&yrend=1970" rel="nofollow - KY Wildcat
Posted By: Bob's2001
Date Posted: February-17-2006 at 11:10pm
Or how about a Mach I style shaker, or one of them bigass blower chrome scoops.
Bob Ed
83 2001
Posted By: Morto
Date Posted: February-18-2006 at 3:41am
And a bug catcher?!?!?
Date Posted: February-20-2006 at 7:19pm
Sorry guy's, I'm a mopar dinosaur, Make mine a shaker.... hey! I got a great idea for mine!
