Throttle Shaft vacuum leak
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3087
Printed Date: November-23-2024 at 10:08am
Topic: Throttle Shaft vacuum leak
Posted By: 83SN2001
Subject: Throttle Shaft vacuum leak
Date Posted: February-23-2006 at 6:25pm
Anyone have a fix for throttle shafts sucking air besides new carb. I just rebuilt it and it is pulling air at the shafts. Other than that it runs like a champ, just a little lean.
Posted By: gigem75
Date Posted: February-23-2006 at 6:40pm
Wrap the shaft in saran wrap tight. Clean the bore for the shaft super clean, Devcon the bore, slide the shaft in and let the Devcon set up. This will only work if the bore is worn, if the shaft is worn it will bind up. That is the southern engineering way. You could drill out the bore and put a bushing in too.
Posted By: Munday
Date Posted: February-23-2006 at 8:17pm
Ford at one time sold a kit for this.
Came with drill bit,4 bushings and reamer.but like gigem said it won't fix bad shaft.
Munday
Posted By: SS-201
Date Posted: February-24-2006 at 3:48am
PUT O RINGS ON THE SHAFT TOIGHT ONE.
SS 201
Posted By: SS-201
OOPS   TIGHT ONES
SS 201
Posted By: 79nautique
Date Posted: February-24-2006 at 8:09am
Holley sells a throtle base plate kit for about 90 bucks at summit racing.
Posted By: dantheman
Date Posted: March-22-2006 at 5:42pm
I am pretty sure that the throttle shafts are supposed to leak a small amount of vacum around them. This is a metered vacum leak. I called Holley Technical Assistance on this before and this exactly what they told me. Who has there boat in the water right now where they could go find out if this is everyone or just me and 83SN2001?
