GT-40 won't start- Need ideas
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=30941
Printed Date: October-08-2024 at 9:13pm
Topic: GT-40 won't start- Need ideas
Posted By: SANTE Claus
Subject: GT-40 won't start- Need ideas
Date Posted: July-28-2013 at 12:46am
2000 Super Air GT-40.
I've replaced the fuel filter, fuel relay, and the low pressure fuel pump. I cycled the ignition a million times. Gasoline isn't making it to the FCC.
What am I missing? Is there a trick to getting the fuel pump to prime?
Thanks for replies
Posted By: lewy2001
Date Posted: July-28-2013 at 10:41pm
Did the problem occur after you changed the filter in FCC???
Is fuel getting to the low pressure pump?
You can make the fuel pumps run continuously by jumpering the EEC Test (STO) connector.
Posted By: Bri892001
Date Posted: July-29-2013 at 12:47pm
Rule out any traditional fuel line problems as well.
The antisiphon valve, which is a check ball fitting right where the fuel line connects to the tanks can gum up.
The lines themselves can collapse and have problems. Some of these have a screen where the fuel gets picked up from the bottom of the tank that get plugged up.
