79 ski tique velvet 1:1 linkage question anothers
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=30948
Printed Date: November-18-2024 at 2:47am
Topic: 79 ski tique velvet 1:1 linkage question anothers
Posted By: Gump
Subject: 79 ski tique velvet 1:1 linkage question anothers
Date Posted: July-28-2013 at 2:24pm
Out on the lake it "sometimes" acts as if it's popping out of gear for a second or two when excelerating. When the throttle is in the forward position, at the tranny, I can push the tranny lever forward a little less than a 1/4 inch forward more. Same for reverse. Should the cable be moving it to the full forward and reverse position? I'm assuming so but not sure how to fix that since any adjustment at the throttle would only lessen the action in one direction or another? New cable?
Also, instead of starting bunches of new threads.
Got new used oil and water gauges in. Free from Pettys marine, in Massillon ohio. Nice guy. What's the norm operating temp? It sits around 150. Is there a thermostat and what temp should it be? 160?.
Posted By: CRob
Date Posted: August-05-2013 at 12:23am
150 is fine. There is a thermostat but I run mine without. You can pull yours and test it out on the stove in water with a thermometer to watch the temp when it opens.
Posted By: boardersdad
Date Posted: August-05-2013 at 3:25am
http://correctcraftfan.com/forum/forum_posts.asp?TID=30803" rel="nofollow - This thread (and one it links to) talks about cable adjustment, and it links to a thread about Morse control rebuild.
Date Posted: August-05-2013 at 3:27am
On my 1984 SN2001:
Thermostat - PCM Ford Engines - 143 degrees - RP026002E
Date Posted: August-05-2013 at 7:32am
CRob wrote:
I run mine without. | Why? There is a reason engines have T stats!
Date Posted: August-05-2013 at 9:45am
I agree. It's not just a filter for shredded impeller vanes.
Engines are carefully designed to run in a specific temperature range. When you run without a thermostat, it takes too long to warm up and doesn't run at the correct temps. The cooler oil may not get everywhere it needs to get, the valves get carboned up, your plugs can foul, even the pistons don't fit the cylinders right. You waste gas and put out stinky exhaust.
It's almost as bad of an idea as putting ethanol in gasoline.
Posted By: JoeinNY
Date Posted: August-05-2013 at 10:37am
There is a noticeable detent (or should be) for forward and reverse on your velvet drive. With the cable disconnected you should be able to feel when you have rocked the lever into forward. If you then move the control to the forward position the cable should line up with the hole location of the shift arm on the transmission without having to move if off the detent. If not then you may need some adjustment, if it does then it is more likely that your transmission is occasionally slipping under load. Make sure it has enough fluid, or add some more anyway (be reasonable about it but a little extra doesn’t hurt them. If that doesn’t help it then it maybe time for a rebuild or to buy a rebuilt one.
1967 Mustang 302 "Decoy"
Posted By: CRob
Date Posted: August-05-2013 at 11:17am
Posted By: CRob
Date Posted: August-05-2013 at 11:18am
8122pbrainard wrote:
CRob wrote:
I run mine without. | Why? There is a reason engines have T stats! |
It was running at like 180-190 with a 143 tstat in it. Granted that was last summer when we had like 50 days over 100, 12 over 110, and a 113 degree day. It ran at 150-160 without. I haven't noticed any problems since. But I appreciate the input gents! Sorry for the thread jack...
Posted By: Gump
Date Posted: August-05-2013 at 5:37pm
Sounds hot... What's the optimum operating temp?
Posted By: Gump
Date Posted: August-05-2013 at 5:44pm
JoeinNY wrote:
There is a noticeable detent (or should be) for forward and reverse on your velvet drive. With the cable disconnected you should be able to feel when you have rocked the lever into forward. If you then move the control to the forward position the cable should line up with the hole location of the shift arm on the transmission without having to move if off the detent. If not then you may need some adjustment, if it does then it is more likely that your transmission is occasionally slipping under load. Make sure it has enough fluid, or add some more anyway (be reasonable about it but a little extra doesn’t hurt them. If that doesn’t help it then it maybe time for a rebuild or to buy a rebuilt one. |
Thanks. It ran fine, knock on wood, after I changed the fluid. The old fluid was thick and dark. I don't think it had been changed in a while. There is sometimes a grumbly or slightly rately noise when going from neutral to reverse sometimes but when in reverse it fine. Think ill replace the dampening plate this winter after the seasons over. Seems like I've read that's a item that wears out a lot.
Date Posted: August-05-2013 at 7:49pm
I have that same noise when first into reverse.
Posted By: Sunshinecustoms
Date Posted: August-15-2013 at 12:18am
I just had a damper plate failure. I certainly would suggest replacing this thing before it comes apart and leaves you stranded on the lake. also sometimes excessive paint or grime around the detent ball area can make it harder to tell where neutral is located and harder to adjust.
