I ordered the wrong fuel filter
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=31034
Printed Date: November-18-2024 at 2:41am
Topic: I ordered the wrong fuel filter
Posted By: boardersdad
Subject: I ordered the wrong fuel filter
Date Posted: August-02-2013 at 2:36am
1984 Ski Nautique 2001
Engine Model PRD WR R10
Pleasurecraft Marine
Right-Hand Rotation from Rear
351 CID -- 255 h.p.
Warner Velvet Drive Model 10-17-003
Direct Drive (1:1)
Mallory YLM554DV Distributor Conversion
As soon as I got the fuel filter I ordered, I knew I had ordered the wrong one.
Here's my fuel pump, and the fuel filter is inside the lower bowl, right?
Here's the fuel filter I ordered like a dummy...
What's the right part number for the fuel filter in my fuel pump on my 1984 SN2001 351W?
While I'm at it, what's the right part number for the carb inlet filter, where the hard line goes into front left corner of the Holley 4-barrel carb?
I need to look more closely at the taper lock fitting nuts for that inlet line going into the carb. I didn't see any flats on the larger fitting. Not sure what the line wrench would be grabbing.
I'm wondering if I'm going to find a bunch of dissolving fuel line in my filter bowl. Damn ethanol crap around here, idiot politicians. Anything to fill the campaign coffers.
Posted By: Dreaming
Date Posted: August-02-2013 at 2:34pm
My fuel filter is in the front of the engine in what looks like a remote oil filter housing... I don't have any pictures at the moment, but would think you probably have a remote filter as well...   see where the fuel lines go from the tank and confirm.   If you think the filter bowl on the bottom of the pump is the only one, I'd take the bowl off, and compare old filter with what is available on SKIDIM or N3's websites
Posted By: ny_nautique
Date Posted: August-02-2013 at 3:15pm
I too have an 84 SN and the fuel/water separator filter that you have ordered goes in the location where Dreaming described. That is the standard location. It should be on the port side of the ski pylon.
Note that the fuel/water separator is probably going to be very tough to unscrew. You'll need to remove the fuel hoses (clamp them first) and you should open the drain from the bottom to let it drain out.
Take the whole assembly out and put it in a vise and use a filter strap wrench to remove it.
Here's the location:
- Jeff
1999 Ski Nautique
Date Posted: August-02-2013 at 6:20pm
Thanks for the replies. I do not have the remote fuel/water separator filter. The fuel line runs straight from the back to the fuel pump and attaches as shown in my first photo.
It's interesting that in the 1978 Ford Marine Power Products 302-351 Parts List, the fuel filter is listed with a bowl and filter element. The worthless list gives no part numbers, though.
The old Pleasurecraft Owners Manual (can't find a date in it) says:
Quote "PCM recommends the use of a Remote Mounted fuel filter and/or water separator and fuel filter on all its engines. Fuel filters are not standard with PCM engines, however, we do offer them as an option to all Boat Builders and Dealers."
I'll eventually switch to that, but for now I just want to change the filter.
I think Skidim has the right filter:
Quote http://www.skidim.com/prodinfo.asp?number=3943" rel="nofollow - FILTER, FUEL PUMP ELEMENT
Indmar Ford OEM Fuel Pumps
Fits into bottom of fuel pump (small canister)
Indmar pt # 98-2021
But of course I'm trying to order this on a Friday afternoon and they closed at 3 pm Eastern....................
You know, that filter looks an awful lot like the fuel pump filter element in my Mercruiser 140 fuel pump, I think I'll compare them.
Date Posted: August-02-2013 at 9:01pm
Do you have a NAPA near you? You may be able to find it there.
That's an interesting note you found in the manual.
Post some more pics of your boat and engine if you get a chance.
- Jeff
1999 Ski Nautique
Posted By: lakedog55
Date Posted: August-05-2013 at 12:20am
Napa has them, I would recommend putting some type of seperater/filter on the boat. It is supposed to have one.
Lakedog55
Date Posted: August-05-2013 at 12:21am
Napa has them, I would recommend putting some type of seperater/filter on the boat. It is supposed to have one. I would als bring your old filter with you to napa.they have a couple of different sizes and if you get the wrong clerk your going to be going back again.
Lakedog55
Posted By: Hollywood
Date Posted: August-05-2013 at 11:31am
You don't have an Indmar why are you ordering Indmar parts?
Posted By: Gary S
Date Posted: August-05-2013 at 1:29pm
Go to NAPA and ask for this filter with their part number sme 187860. This should be it but take yours to compare. I think that this pump is used on Mercruisers and Commanders. It was also a replacement pump that would fit small block Fords and sold by Summit ,ski dim and others. I bought one for a spare before I was able to rebuild my original pump.
Posted By: GlassSeeker
Date Posted: August-05-2013 at 1:56pm
were there ever any black pcm's? black is usually Merc
This is the life
Date Posted: August-05-2013 at 2:05pm
Looks like silver under those scratches. Wondering where 255hp came from.
Date Posted: August-05-2013 at 2:11pm
All PCMs have been black since ~1994.
Of course, his is a '84, so its been repainted. My guess is that it has been apart, since that does not look to be an original fuel pump. The large Fram filter/water separators were added sometime in the '80's... but I cant say for sure whether it should be there on a '84.
Date Posted: August-05-2013 at 7:38pm
I called NAPA and they ordered me their version of my Mercruiser fuel pump filter, Quicksilver 35-49088Q2, Sierra 187860, but they cross referenced it to a NAPA filter made by Wix. 7 bucks and change. Picked it up this afternoon. I'll compare it when I open the fuel filter. I think it's the same one, if not it'll be a spare for the Merc.
Date Posted: August-05-2013 at 7:45pm
From page 4 of the PCM Engine Service Manual, "Horsepower and Type".
I can't find any date in that manual. Is it incorrect for a mid-80's engine?
Date Posted: August-06-2013 at 5:02am
Im still wondering why your PCM has Mercruiser parts???
Mix and Match? or?
If it's a Chevy you may have 260 horse
This is the life
Posted By: Gary S
Date Posted: August-06-2013 at 11:25am
Mix and Match? or?
Can't be a Chevy,it's a Carter pump for a Ford. This pump will fit
any small block Ford no matter who marinized it,ie MerCruiser, HM,
PCM,Commander,Intercepter etc. MerCruiser marinized Fords too.
Here is my spare which is the same
Here is my original Carter which after a rebuild have reinstalled
here it is at http://www.summitracing.com/parts/crt-m6696/applications/?prefilter=1" rel="nofollow - Summit
Date Posted: August-08-2013 at 8:58pm
I noticed that the owner's manual says 240 hp, and the service manual says 255 hp.
Date Posted: August-11-2013 at 9:11pm
NAPA's Wix version of the 187860 fuel filter was the right one.
Ay thoughts on the hp question above?
Posted By: Gary S
Date Posted: August-11-2013 at 9:25pm
First liar never has a chance,most likely you'd be lucky if it got to either
Date Posted: August-11-2013 at 9:42pm
Yeah, I agree. It's like my old Mercruiser 140. The sterndrive reduces the hp at the prop, plus it's 40 years old. I don't want to know what I really get... but it's been great for the big old pontoon. And I've towed plenty of "new" boats off the water with it.
I'm just curious why one manual says 240 hp and another 255 hp, and where the higher number came from. Maybe it's a later year manual.
