Ignition
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=31127
Printed Date: November-18-2024 at 2:51am
Topic: Ignition
Posted By: Bones71
Subject: Ignition
Date Posted: August-07-2013 at 11:48pm
Guys, ok I try to explain the best I can here what happened tonight. I think that the ignition switch stuck but let me know what you think. I pulled into the beach to put on the barefoot boom ( no I didn't beach it) I went to go back out turned the boat over and the starter was making a funny noise and it wouldn't stop turning over. The boat started but it sounded horrible. The engine ran with the starter still engaging. I shut the motor off but all the boat would do is keep trying to turn over the engine. I was in panic mode and got the boat back to the beach. All this time the starter trying to start the motor at the beach I tried turning off the ignition switch button. Didn't work.i tried putting the boat in forward to kill the starter and that didn't work. Now I was clueless. Then I just tried turning the key back and forth a couple time and it finally stopped. I took a breather and tried to start it back up and it was fine. I took the boat out and did some skiing and it didn't give me anymore problems. Now is it my key switch getting bad? And why wouldn't turning off the ignition button on the dash kill power to the starter? Seemed weird to me. Any insight would be appreciated.
   My dog fell out of the boat at the dock and I hit a wing dam and gouged one of by tracking fins. I did not damage my shaft or prop though. Other than that we had a good time tonight . Good times. Tony.
That money talks, I'll not deny, I heard it once: It said 'Goodbye'
Posted By: boardersdad
Date Posted: August-08-2013 at 1:00am
Check out http://correctcraftfan.com/forum/forum_posts.asp?TID=31095" rel="nofollow - this thread .
Posted By: SNobsessed
Date Posted: August-08-2013 at 6:33am
Sorry to hear of the problems, I'm familiar with wing dams!    Sounds like Starter relay is bad.   Just found out there IS a difference marine vs. auto part, so best to get one on order.
Date Posted: August-08-2013 at 7:10am
I agree with the starter relay (solenoid) problem. Get the VOM out and do some testing. The contacts are welded together. What's the condition of the battery? Have you done a load test on it? Hopefully it's not a deep cycle used for a starting battery!!
Date Posted: August-08-2013 at 10:30am
Im not convinced its not a faulty ignition switch based on the symptoms... like Pete said, get out the multimeter! If its an intermittent problem, then you may want to consider replacing both the switch and relay... both are cheap.
Posted By: Bones71
Date Posted: August-08-2013 at 2:06pm
Thanks very much for the info. I'll do some looking into both the starter switch and relay and probably change both to be safe. Yeah as far as that wing dam, it was a lateral dam that runs with the shoreline. there on lt two on the Mississippi. One in the Leclaire pool and one in the Davenport. i Knew about the Davenport one but you would never know about the leclaire one. I know now. Thanks again, Tony.
Date Posted: August-08-2013 at 7:58pm
like Pete said, get out the multimeter!   both are cheap.
Originally posted by Bones71 Bones71 wrote:
Thanks very much for the info. I'll do some looking into both the starter switch and relay and probably change both to be safe. Tony.
Tony,
Don't become just a "part changer", Test first. Yes, they are cheap but testing will tell you where the problem is really at. So, what about the battery question??
Posted By: Bones71
Date Posted: August-09-2013 at 12:50am
Pete, yes I know. You and Tim are right. I need to find why it stuck. I have ordered the relay but I will find out where the voltage problem is. I talked to Vince at SkiDim. He ran me thru all common problem where my problem could occur. He said the switch was probably not it.
As far as the battery goes I guess I don't know if its a deep cycle or not. Guys remember I'm a noob. Most Everything I know and learned was from this site. The battery has been flawless so far but I'm thinking what I have is a grounding or connection problem. I need to talk to the maintenance guys at work and have them run me over where I need to take the readings with the multimeter and what I should see. I will pull the battery and have a load test on it. I'll post results. Thanks very much for the help. Tony
Posted By: Bri892001
Date Posted: August-09-2013 at 9:49am
A deep cycle battery could very well say so right on it. Unless the decals and stuff have come off.
Be a little suspicious of any battery that says "marine." They are often times deep cycle. Our boats want a regular starting battery. Marine starting batteries would be ok if they fit, but this is one instance where you want the regular automotive part.
Posted By: 62 wood
Date Posted: August-09-2013 at 11:45pm
Not sure how accessible the battery is in your 89? I try to keep a wrench close by so I can unhook a battery cable if this or another electrical short happens.
btw, you going down to the Muscatine boat show next weekend?
http://www.correctcraftfan.com/diaries/details.asp?ID=1117&sort=&pagenum=6" rel="nofollow - 64 American Skier
62 Classic..
73 Ski Nautique
Posted By: Bones71
Date Posted: August-10-2013 at 1:59am
Steve, the battery is right there at my feet. Very easy to get to. Good call on the wrench. I did not know about the boat show. I think I'm heading to Dubuque for a guy weekend on the river next weekend. I would like to go to the boat show though. This year has been busy. Tony.
Posted By: Bones71
Date Posted: August-10-2013 at 10:21pm
Pulled the battery today to start finding my problem. Had a load test done on it and a cell was bad. The battery was bad. Went to Walmart and picked up a Everstart 65N to replace the old one. I also replaced the battery terminal clamps. Had the boat in the water today and had no issues at all. I'm still going to look everything over but that's where I'm at so far. Tony.
