Running warm
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=31406
Printed Date: November-17-2024 at 11:28pm
Topic: Running warm
Posted By: Bones71
Subject: Running warm
Date Posted: September-01-2013 at 7:02pm
Guys I can't seem to get my boat to cool down the way It think it should. I am running a 160 degree thermostat in it. It hardly ever goes down to 160. I'm always running 170 -180. It's driving me nuts!! I checked all hose connections to see if I was sucking air. They all seem tight. I checked my strainer and its good. I do see some air bubbles in it though. Should there be? I have a tee before the strainer that I'm going to remove To see if that is a problem. The tee is a fresh water tee with a check ball in it to Run off the hose. Maybe it's sucking there. its drivin me crazy!!! Any thoughts? I also thought the thermostat was maybe not opening all the way but I don't know. Your thoughts? Thanks so much. Tony.
------------- That money talks, I'll not deny, I heard it once: It said 'Goodbye'
Posted By: bhectus
Date Posted: September-01-2013 at 8:06pm
Take the check valve out of play. They will sometimes stick. Happened to my BFN. I don't think you should have bubbles in your strainer. Sounds like you have an air leak somewhere. Could be the gasket on the strainer bucket also.
------------- '02 Ski Nautique 196 w/ 5.7 Apex bowtie - Sold '87 Barefoot - sold '97 Super Sport Nautique - originally custom built for Walt Meloon '97 Ski Nautique '83 SN 2001
Posted By: TX Foilhead
Date Posted: September-01-2013 at 8:24pm
This time of year when the water temps are close to 90 that's not unusual, I see similar temps. I just keep a litter sharper eye on the guage, make sure that it has a good power and ground if those aren't right mine reads a little hot. I worry more when it won't cool just after a restart, or when I bump up the RPM's on the way back to the skier. I'm really more intrested in that it's behaving normal than the actual temp.
Posted By: Bones71
Date Posted: September-01-2013 at 9:23pm
I pulled the strainer screen on the way back on the river tonight to just see what it would do and it ran 170 all the way back to the boat ramp. It drops when I slow down and take off again. Seems normal but weird. Then it goes from 160 to 170. When I was headed up river early in the day the temp spiked and safety killed the engine. I never experienced that before. Took the boat near shore and checked all places I could. Removed the strainer screen and let it sit for 20 min. Then on the way back it read 170 all the way.ill try again tomorrow. Thanks.
Posted By: lewy2001
Date Posted: September-01-2013 at 10:08pm
Tony I would use the recommended 143 degree thermostat. The 160 is meant more for the EFI engines. It will then run around the 160 mark most of the time.
http://www.skidim.com/prodinfo.asp?number=RP026002E" rel="nofollow - 143 Degree Thermostat
Posted By: bhectus
Date Posted: September-01-2013 at 10:31pm
Lewy is correct, carbed engines should be running a 143 stat. 160 stat is for EFI. When was the last time you checked your impeller?
Posted By: Bones71
Date Posted: September-02-2013 at 1:09am
The impeller is where I started. It's in really good shape. My rwp is dripping so I thought I would take it apart and give it a look. I am going to rebuild it this fall. I replaced the gasket and thought it would stop the drip but no. The impeller was in great shape. I thought I would like the 160 stat but I guess it's not for my boat. I'm going to take the tee off in the morning and bypass it. I'm going to order a 143 degree stat. They say the boat performs better and a little higher temp/ more efficient but at 170 it seems hot to me. Thanks again. Tone.
Posted By: backfoot100
Date Posted: September-02-2013 at 7:44am
You're getting bubbles in the strainer which indicates a gasket leak. You have a drip on the RWP which could also be letting air into the system (if it isn't the impeller seal, it has to be the shaft seal). Both of which can impede the water flow efficiency through the engine. Then, on top of that, the wrong thermostat is in there. You're extremely lucky that it's running at 180 degrees.
Fix that stuff and you should be fine.
Eddie
Posted By: dwouncmd
Date Posted: September-02-2013 at 9:06am
bhectus wrote:
Lewy is correct, carbed engines should be running a 143 stat. 160 stat is for EFI. When was the last time you checked your impeller? |
I don't think I have seen this stated explicitly before. Why is that?
I have a 143 on the Tique (carbed 350) and a 160 on the SN (carbed 351). Both seem to perform fine. I will admit the SN seems to get a lot warmer between runs with the motor off, but as soon as I restart, it comes down quickly, and frequently dips below the 160 mark.
Bones, I had similar problems before the transmission rebuild/shaft replacement on the SN, but when I replaced the transmission oil cooler, I went through the cooling system from the pickup to the pump/impeller making sure all the connections were tight and gaskets in place, and problem solved.
If you have air bubbles in your strainer, you might check to see that the O-ring is still there. They are easy to drop without noticing; thankfully, they usually fall into the bilge.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=6535&sort=&pagenum=2" rel="nofollow - 89 SN <a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
Posted By: SNobsessed
Date Posted: September-02-2013 at 9:54am
dwouncmd wrote:
I replaced the transmission oil cooler |
Tony - Weren't you having tranny fluid disappear? Maybe these 2 problems have a common cause.
Posted By: Bones71
Date Posted: September-02-2013 at 11:52am
RRR, yes I have a lot of fun things going on right now. I definitely have some kind of tranny leak. I need to pull it. I thought the temp thing was an easy fix. When I ordered the 160 stat I was originally going for the 143 but they talked me out of it. Off to the river today after the tee pulled and I'll open up the oil cooler and inspect. Thanks.
Posted By: Bones71
Date Posted: September-02-2013 at 7:36pm
Found my tee like this. The gasket was torn. removed it along with the strainer. I'm going to run it straight and see where she temps.
Posted By: boardersdad
Date Posted: September-02-2013 at 11:31pm
Bones71 wrote:
When I ordered the 160 stat I was originally going for the 143 but they talked me out of it. |
Tony, who talked you out of it, and why would they recommend running something other than the spec? The raw water cooling system is very basic and it's not like some modern improvement has come available (other than more reliable impeller materials, I suppose). Using a 160 degF thermostat intead of the 143 degF spec just sounds like a bad idea from the start.
Steve
Posted By: Bones71
Date Posted: September-03-2013 at 12:12am
I know. I should just listen to guys on here. I don't want to knock SkiDim. They have been great with all my needs. My motor is a repowered 351. I think they saw it as a better way to go so I said ok. they said 160 was not really that warm I thought "ok. That will be fine" I'm going back to a 143. I had a issue when I bought the boat in the spring. The stat would not close and therefore the engine would not come up to temp. To move things along the previous owner put in a 170 stat. I changed it out to a 160 with the advice from SkiDim knowing you guys said 143. Yep still learning. Baby steps. tony.
Posted By: lewy2001
Date Posted: September-03-2013 at 9:44am
The 143F Thermostat does not let the motor run at 143F it will run at around 160F. So your 160F Thermostat running at 170-180F seems about right.
Posted By: dwouncmd
Date Posted: September-03-2013 at 10:01am
lewy2001 wrote:
The 143F Thermostat does not let the motor run at 143F it will run at around 160F. So your 160F Thermostat running at 170-180F seems about right. |
Well maybe I have a 143 in the SN after all (I haven't opened it up to take a look), it will run below 160...
Date Posted: September-03-2013 at 12:30pm
I run a 160, the only times it runs at much different temps than others report is during the winter and sometimes in August when our water is in the mid 90's. Not sure a 143 wouldn't run around the same temps in August, I've never used one on a carbed motor in water that warm.
Posted By: TX Wind
Date Posted: September-03-2013 at 2:26pm
I run a 160 in mine as well. I've been running it for 3 years in the TX heat. And like Don says, our WATER temps, not air temps are in the mid 90's. I typically see the boat running around 175 degrees. It holds fairly constant within a few degrees.
The reason they recommended a higher temp t-stat is because there is some argument for better atomization of fuel at a slightly higher temp. The 351 likes a minimum of about 155 degrees for proper atomization of the fuel. Some places have water temps that make that a difficult temperature to realize. So as an all around, the 160 is a better option if you're selling t-stats to the masses. It also provides warmer water for a shower if you have one.
Well...that's the way it was presented to me anyway. Regardless, I run a 160 t-stat. Engine is 175 degrees in warm water all day everyday. We barefoot incessantly which means we see WOT quite often. 175 degrees is nothing to worry about. Most cars on the street are running much warmer.
http://www.correctcraftfan.com/diaries/details.asp?ID=5622" rel="nofollow - 1967 SN Interceptor
1985
Posted By: Bones71
Date Posted: September-04-2013 at 12:43am
SNobsessed wrote:
Tony - Weren't you having tranny fluid disappear? Maybe these 2 problems have a common cause. | I was wondering about the fluid I was adding. I have been adding a Valvoline Dex/Merc. Is that the right weight trans fluid. It does not say on bottle. Tony.
Posted By: dwouncmd
Date Posted: September-04-2013 at 8:20am
Dex Merc is the right stuff. If you have a leak, it leaks red (ask me how I know )
Posted By: Bones71
Date Posted: September-04-2013 at 7:25pm
dwouncmd wrote:
Dex Merc is the right stuff. If you have a leak, it leaks red (ask me how I know ) | Hate to ask. But ok " how do you know?"
Posted By: dwouncmd
Date Posted: September-04-2013 at 8:38pm
My transmission/shaft Odyssey detailed in several other threads, all boring.
Posted By: Bones71
Date Posted: September-11-2013 at 12:44am
Guys, put in the 143 degree stat and all was good. Temped at 160 all night. Felt good seeing stay put. I removed the tee and the strainer and ran straight off the pick up. Now I want to put back in the strainer. I have one question. On the PVC fittings that connect to the strainer body.... I just used white plumbers thread tape on the threads. Is this ok to use or should I use another kind of thread seal? Tony.
Date Posted: September-11-2013 at 1:37am
That's it, I haven't seen anything else for threaded PVC. Just for good measure, make sure there isn't anything stuck in the cooler when you put the strainer back on. Doesn't take too many leaves to clog it up. Out of curiosity, has your water temp dropped any? Here the shorter days will drop the temp even though the highs and lows are about the same as they are in August.
Posted By: Bones71
Date Posted: September-11-2013 at 2:01am
It's been really hot here the last few weeks. Water temp is pretty warm. I think it's headed down soon. Today it was 97 out and Friday is supposed to be in the 70's. I don't want it to cool down but I work in a hot fab shop and am looking forward to cooler temps. Tony.
Date Posted: September-14-2013 at 7:43pm
Bones71 wrote:
It's been really hot here the last few weeks. Water temp is pretty warm. Tony. | Tony, The water temp really should not impact the engine cooling too much. Even if the water temp was 80, the delta T is still wide. You should have plenty of water flowing to cool the engine. I would suggest looking at other issues. Have you done a bucket yest on how much water your are actually pumping?
Posted By: Bones71
Date Posted: September-14-2013 at 9:38pm
Pete, all is good. No problems here any more. Had her out today and she ran like a champ. Temping right where it should. I think I was sucking air somewhere.either the flush tee or the strainer. I'm going through everything before I put them back on. I'm just running off the pickup right now. Thanks though. Tony.
