fitting new throttle cable
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=31589
Printed Date: November-17-2024 at 11:19pm
Topic: fitting new throttle cable
Posted By: d4vy
Subject: fitting new throttle cable
Date Posted: September-18-2013 at 5:14pm
hey guys,
new to the forum so hopefully it can be a help as i plan to restore a 1992 2001 nautique over the course of the harsh winter that we get here in ireland!
before we take the boat out for the winter period tho i had planned on doing some wake boarding until the throttle cable broke at the week end...
i got the new throttle cable today and i plan on fitting it 2moro night..
can anyone guide me in the right direction in regard to the throttle end of the cable and how it attached to the throttle lever??
there is brass head that screwed off the old cable straight onto the new one (il attach a pic if i can find out how) and i imagine that pushes in somewhere but there is a small hole thru the centre that im not sure about..
any help will be appreciated!
thanks
Posted By: dwcar
Date Posted: September-19-2013 at 11:08am
Welcome Davy,
I think those cables are the same on both ends so it does not matter which end goes where. The end that attaches to your throttle for the driver has the little brass head that you speak of. The small hole is for a cotter pin once you have it in place. The end that attaches to your carb will have a piece that is spring loaded and attaches to your carb linkage. there is a backup nut on it. I would recommend that you tape your new cable to the old and pull the old out while pulling the new into place. This is how my 83 is set up. I assume yours is similar. Lets see the pics!!
------------- 83Ski
Posted By: d4vy
Date Posted: September-21-2013 at 2:39pm
Got the new throttle cable fitted (Altho 16feet was 2feet short) so few improvisations in the cable route!!
The problem I have now is that when I push the throttle lever forward to put the boat in gear it wants to rev before the boat is actually in gear.. U neary have to give it a hard rev to get it into gear! Also the same for reverse. Very hard to find as u have to give it a good rev to let it find reverse!
Any reasonable explanation as to what the issue is??
Ps will upload photos as soon as I figure out how!!
Posted By: Air206
Date Posted: September-21-2013 at 3:41pm
Davy:
You are mixing apples and oranges...... get shift cable adjusted and working right - THEN adjust throttle cable. There are A LOT of good posts on fine tuning adjustments..... do a google (not site search) ie:
at google search box type the following-
site:www.correctcraftfan.com "throttle cable"
I had similar issue and fixed it with those posts.... also a morse control manual is in reference session... READ ALL of it. It describes adjustment procedures. You will knock it out easily....without the boat in the water.....
Steve
------------- https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206 http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot 78 SkiTiq
Posted By: KRoundy
Date Posted: September-21-2013 at 4:46pm
There are some links on shift cable adjustments in the FAQ:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=27356&title=ccf-faq" rel="nofollow - CCF FAQ
------------- Previous: 1993 Electric Blue/Charcoal Ski Nautique Current: 2016 Ski Nautique 200 Open Bow
Posted By: gR@HaM
Date Posted: September-22-2013 at 6:33pm
Hi Davy good to see someone else from this side of the water. Show us yer boat!!!
------------- '82 Ski Tique
Posted By: d4vy
Date Posted: September-22-2013 at 9:10pm
Air206 wrote:
Davy:
Steve |
i havnt went near the shift cable tho.. the problem has only arisen since fitting the new throttle cable! if i push the throttle cable forward or back it just wants to rev and doesnt go into gear like it should.. to put it into gear u have to jerk it forward and back again quickly before you can put on the power!
altho now to add to my problems we were out last night and the steering went.. cutting a long story short when we took off the housing at the back of the wheel the cog that comes from the wheel itself (see attached photo) is missing quite a few splinds.. this must have happend over a period of time but some of the broken splinds nestled themselves into the grooves of the bigger cog thus meaning the wee cog cudnt run past it giving me a very limited amount of steering!
need to find a new cog now if anyine can help me out with a name for it or a source this side of world
Posted By: gR@HaM
Date Posted: September-23-2013 at 7:44am
Looks like you need a replacement big t helm, I got mine second hand from the forum if you ask around I'm sure someone will have one to sell. Let me know if you need a new cable as have a UK source
Posted By: d4vy
Date Posted: September-23-2013 at 4:45pm
no worries graham, i shall post a new topic and see what it brings..
@steve i done a google site search and found a thread on the very topic i was looking for.. in theory it looks like i should have my problem sorted.. we will have to try it out and see when i get the steering fixed.
