What is this connection on my carb for?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=31693
Printed Date: September-29-2024 at 12:47pm
Topic: What is this connection on my carb for?
Posted By: CrazyCanuck
Subject: What is this connection on my carb for?
Date Posted: October-02-2013 at 9:09pm
Hi all.
I got my new carb for the 78, and it has a barb fitting for a vacuum line that goes into the primary body. My existing carb was from a car, and did not have this fitting. I noticed that the Holley 4160's have a similar fitting, just that its not a barb, but a smoother vacuum line connection. Is it just to be capped off, or does it serve a function?
Thanks
Corey.
------------- https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Date Posted: October-03-2013 at 10:25am
It can be capped off, or you can plumb your PCV valve to it. This comes in handy if/when you want to replace your intake with a taller one, and want to eliminate your spacer in order to fit everything under the engine box. Only the newer marine 4160's have this vacuum port.
Date Posted: October-03-2013 at 1:01pm
Ok thanks. My pvc valve goes to the spacer under the carb, so I will cap it.
