1983 Nautique 2001 with mercruiser 454
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=31753
Printed Date: October-08-2024 at 5:20pm
Topic: 1983 Nautique 2001 with mercruiser 454
Posted By: sun
Subject: 1983 Nautique 2001 with mercruiser 454
Date Posted: October-10-2013 at 9:01pm
I have a 1983 Nautique with a 454 mercruiser, mechanic has redone crank, he then installed new lifters with old cam, cam then lost a lobe. I am based in South Africa, and have been struggling with the local mercruiser agents, they not helpfull at all, dont even know their own serial no's. Any suggestion where I can get a good quality cam, with new followers, no Kong Fong products. Also any one sure of mark iv/v/vi series this motor is? engine no:22642 block casting 14015445 gmt14 any help would be much appreciated, my 1st Nautique, and would like to restore it to new.
Posted By: 89Martinique
Date Posted: October-11-2013 at 12:46am
many good cams, I prefer edelbrock and Crane most. Others also like Comp cams. They are all US made. They are most likely the same cam, Edelbrock is the same as summit cams as there is only 3 cam grinders in the US.
------------- Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!)
1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus
1984 E-Scow
Keuka Lake,
Posted By: hotboat
Date Posted: October-11-2013 at 11:17am
Is that standard or reverse rotation?
------------- Brian
Date Posted: October-11-2013 at 11:40am
That Merc 454 is either non-original (most likely) or a very oddball factory engine (pretty unlikely). The 14015445 casting number indicates that its a Mark IV.
We need to know whether RH or LH. What prop does the boat have, and was it known to move under its own power with it? If thats an unknown, then pull the timing cover off and snap a pic of the timing set.
Posted By: phatsat67
Date Posted: October-11-2013 at 11:48am
TRBenj wrote:
pull the timing cover off and snap a pic of the timing set. |
+1
Posted By: ArtCozier
Date Posted: October-13-2013 at 10:29pm
Tim, I'm not 100% sure of this on big blocks, but most of the GM engines use the same cam LH or RH. They just reverse the rotation direction of the cam by using gears to drive it off the crank instead of using a chain. Art
------------- "Art"
Posted By: oldcuda
Date Posted: October-13-2013 at 11:10pm
Only thing they have in common is they spin in the same direction.It is a reverse fire and ground totally different.If you put them side by side the lobes are in different positions and the front of cam is different to take the timing gear.
Date Posted: October-13-2013 at 11:31pm
Well, now I know more than I thought I did before! That's what I get for "ass-uming! Art
------------- "Art"
Posted By: sun
Date Posted: October-14-2013 at 6:51am
Posted By: sun
Date Posted: October-14-2013 at 6:52am
sun wrote:
| Any info on a cam supplier?
Posted By: baitkiller
Date Posted: October-14-2013 at 9:29am
This may help. The part numbers you need are post scripted RH. Crusader parts may be easier to source than merc for you.
http://www.jerrysmarine.com/cgi-local/show_page.cgi?page=42&reset=757
------------- Jesus was a bare-footer.............
Date Posted: October-14-2013 at 11:07am
Since PCM bought out Crusader, they have a good many of the older Crusader parts. You might try www.SkiDim.com and send them an email with the Crusader part # and a description of the cam. (RH 454 and any numbers you can find) Art
------------- "Art"
