distributor question
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3216
Printed Date: November-23-2024 at 10:15am
Topic: distributor question
Posted By: David F
Subject: distributor question
Date Posted: March-20-2006 at 10:10am
Ok, I have my '77 Martinique tentatively sold to a friend (I know, bad mistake). The only thing I am concerned with is the automotive distributor. This issue did not bother me because I am very diligent in check the integrity of the fuel delivery system...so not much worry for me of starting a fire/explosion.
However, the potential liability of selling the boat to someone without the proper marine distributor gives me pause for concern. So, I am thinking of replacing the distributor with a breakerless marine unit. BTW, I purchased the boat with automotive carb, fuel pump, distributor, starter and alternator. I have since changed all over the years EXCEPT the distributor.
Suggestions on best distributor deals welcomed. Thanks in advance.
Posted By: bkhallpass
Date Posted: March-20-2006 at 10:36am
David,
Glad you found a good home for your Martinique. I'm the same way. I have a hard time selling something if I know it isn't right. Heck I even replaced all the mirrors on my old 68 pickup before I GAVE it to one of my brothers. BKH
Posted By: john33617
Date Posted: March-20-2006 at 11:32am
only difference is the vent hole has a screen , big thing is the advance curve
Posted By: David F
Date Posted: March-20-2006 at 11:45am
I also thought the caps were sealed to the distributor via a gasket.
My current distributor is vacuum advance. It runs well, but I am sure a distributor with proper mechanical advance for a marine engine would perform better. Also, I think it would be best to get rid of the points for the new owner so he has one last thing to worry about (i.e. not mechanically inclined).
So far, I am leaning toward a Mallory marine unit #MAA-YLM554CV at $240.00
Posted By: surroundsound64
Date Posted: March-20-2006 at 12:03pm
Just make sure he is aware of the situation.
------------- 1981 Ski Nautique 2000 SAN
Looking for a 2000-2006 SAN
Posted By: rmcdonald
Date Posted: March-20-2006 at 6:46pm
Hi David
A good alternative to replacing you whole distributer is to replace the points with a electronic ignition kit.
I have replaced my points with a product from
/www.pertronix.com/
Its called Ignitor electronic ignition.
Takes about 10 minutes to install.
Just follow the instructions.
It replaces the points in your distributor with a hall effect pick up and a new rotor button. The new rotor button has 8 magnets in the base.
Works very well. I have seen other posts from people say they are happy with the product as well.
Don't know the cost as I am in Australia and paid in Aussie Dollars, probably much cheaper in the US.
Posted By: 79nautique
Date Posted: March-21-2006 at 6:56am
I use the YLU-554-CV
Posted By: David F
Date Posted: March-21-2006 at 7:06am
I believe that is the "Unilite" version. I once had a mallory unilite distributor installed in my 1970.5 Rally Sport Camaro and it worked flawlessly for many years.
However, for a $70 premium just to sell does not make it a worthwhile investment for me at this point. Peach of mind and reliabilty at a cheaper price is what I am after.
Posted By: SS-201
Date Posted: March-22-2006 at 3:37am
Mallory now has a magnetic pickup instesd of the optic style. The new magnetic one for marine is much more stable, but both are good. However the optic unit cost about 90 and some dollars to replace, and should carry a spare.
------------- SS 201
Posted By: David F
Date Posted: March-22-2006 at 8:06am
I believe I am going to go with the Mallory YLM554CV. It is the Marine magnetic pick up unit that sells for $240.00 via Summit Racing.
Anyone have a less expensive source or brand?
BTW, I have a LH (conventional) rotating engine.
Date Posted: March-22-2006 at 11:42am
http://cgi.ebay.com/ebaymotors/Prestolite-Marine-Distributor-44-916_W0QQcmdZViewItemQQcategoryZ33690QQitemZ8043862004QQrdZ1
http://cgi.ebay.com/ebaymotors/351-LH-Ford-Marine-Distributor-PRESTOLITE_W0QQcmdZViewItemQQcategoryZ31284QQitemZ4624199298QQrdZ1
couple of point style dist on ebay might save a buck or two even if you convert it but really not needed.
Posted By: David F
Date Posted: March-23-2006 at 9:59am
Thanks 79.
I am going to place a bid and go this route. Why did I not think of this? Doh!
Update: Won distributor for $68.00 (including shipping). Thanks again.
Date Posted: March-23-2006 at 10:56am
I would suggest you lay the two side by side before you install and make sure the housing are the same and that the gear is the same as well. Worst come to worst you may have to swap gears but it's pretty easy just drive out the roll pin and slide it off.
Posted By: David F
Date Posted: March-23-2006 at 11:01am
Yep, I think you are correct about swapping drive gears. Last year I experimented with making my own Prestolite/GM magnetic pickup HEI setup. I had to swap the gears then, but went back with the old distributor as I never could get the frankenstein to run like I wanted.
Posted By: jefmar
Date Posted: March-28-2006 at 8:00pm
David - I'm curious about the ebay prestolite distributors.. Where any modifications required? Does the advance work well?
------------- 1989
Ski Nautique 2001
Posted By: David F
Date Posted: March-29-2006 at 7:08am
I just received the distributor last evening. Too wet here in Austin right now to work on the boat.
Posted By: David F
Date Posted: April-03-2006 at 3:12pm
I installed the Prestolite marine breaker distributor yesterday along with new PCM plug wires and a new PCM coil. I also installed the new Holley Marine 4160 carb. Man let me tell you the engine has never run this good. I set the timing to PCM specs and it just purrs. Fires instantly no matter if having set for 30 seconds or 30 minutes. the new Owner is going to be very pleased.
The new Owner and I are heading to the lake tomorrow for final testing/tuning and a bit of instruction on how to drive an inboard boat. So, I will know more about the advance curve on the new distributor, but I am confident it will be good.
BTW, I did NOT have to switch the drive gears.
Posted By: woodboy
Date Posted: April-03-2006 at 6:47pm
David, I know I'm reading an old post but where are you finding the mallory dist for $240? I looked at summit last night and it was $309. Thanks Rob
------------- Lake Livin' Rocks
Posted By: David F
Date Posted: April-03-2006 at 7:24pm
Woody:
Here you go (note that my engine is LH)...
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MAA%2DYLM624AV&N=4294925143+400249+4294881256+4294908395+115&autoview=sku - Mallory marine breakerless distributor
Date Posted: April-03-2006 at 7:47pm
Dave that was a chevy dist, shouldn't have been a ford?
Woodboy, what you want is either a YLU-554-CV or a YLM-554, the YLU is more expensive and has an optical pick-up vs a magnetic for the YLM
If you have a standard rotation engine then order a 554-DV the CV is reverse rotation, different gear
Date Posted: April-03-2006 at 7:48pm
Woodboy, what you want is either a YLU-554-CV or a YLM-554-CV, the YLU is more expensive and has an optical pick-up vs a magnetic for the YLM
Posted By: David F
Date Posted: April-04-2006 at 11:55am
ooops, my bad. The Ford unit is the same price....
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MAA%2DYLM554CV&N=4294925143+400249+4294881256+4294908395+115&autoview=sku - Ford distributor
