4160 carb
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32357
Printed Date: November-17-2024 at 1:52pm
Topic: 4160 carb
Posted By: racingnc
Subject: 4160 carb
Date Posted: November-30-2013 at 3:46pm
I'm looking for thr front bowl to a 4160 that has the screw to adjust the float. Emil me from the site if you have an old one laying around. This is fro a 4 barrel 4160 that goes on a PCM 351 Thanks,
Matt
Posted By: Dreaming
Date Posted: December-01-2013 at 7:08pm
I don't think 4160 bowls from a marine carb have the float adjustment on the outside. If you desire that feature, there was an aftermarket carb mentioned on a couple other threads recently that has that benefit. You might be up for a whole new carb if you are unable to make the adjustment internally.
Posted By: JPASS
Date Posted: December-01-2013 at 9:45pm
Dreaming wrote:
I don't think 4160 bowls from a marine carb have the float adjustment on the outside. If you desire that feature, there was an aftermarket carb mentioned on a couple other threads recently that has that benefit. You might be up for a whole new carb if you are unable to make the adjustment internally. |
I think http://www.quickfueltechnology.com/carburetors-marine-series/m-600-marine-carburetor.html" rel="nofollow - THIS is the carb you're talking about.
Posted By: Dreaming
Date Posted: December-02-2013 at 5:00pm
Yep, that's the one. the adjustable seat can be seen in the picture on the top of each bowl.
Posted By: backfoot100
Date Posted: December-02-2013 at 5:51pm
You can go buy a Holley float bowl that has the external float adjustment and put it on. They aren't marine specific. Should be able to get one from about any speed shop. Holley just never opted to put them on a stock marine carb.
Eddie
Posted By: ArtCozier
Date Posted: December-09-2013 at 3:36pm
The external adjustments were on the marine carbs until about 1976; that's when the USCG outlawed the sale of them on marine applications.
------------- "Art"
