Difference in Auto and Man Bilge
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3243
Printed Date: September-23-2024 at 5:46am
Topic: Difference in Auto and Man Bilge
Posted By: Floatmyboat
Subject: Difference in Auto and Man Bilge
Date Posted: March-24-2006 at 8:15pm
I have a 89 2001 and on the Dash there are two buttons for a bilge one says Auto and the other one says Manual Just Curious on the difference
------------- 75% of the earth is water
Spend 3/4 of your time on the Water
Posted By: 81nautique
Date Posted: March-24-2006 at 8:27pm
Your bilge pump should have a float switch next to it.. In the manual mode it is simple pump on or off, used for emptying water while the boat is occupied. The auto mode is for pumping out the boat when it is not being attended to, like an overnite tie up or folks that leave their boat in the water all the time. In auto mode the pump will kick on when the water level inthe bilge raises the float switch high enough.
------------- You can’t change the wind but you can adjust your sails
Date Posted: March-24-2006 at 8:29pm
Thanks Does the ignition button need to be on for the auto bilge to work
Posted By: Bob's2001
Date Posted: March-24-2006 at 8:44pm
It does not, at least on my boat.
------------- Bob Ed
83 2001
Posted By: tonydjd
Date Posted: March-25-2006 at 5:38am
Usaually the ignition does not need to be on if the switch was wired correctly easiest way to find out use a test light or better yet open dog gog house lift float switch by hand you should hear the bilge kick in if the switch is on auto and wired correctly
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=1061&sort=&pagenum=1&yrstart=1986&yrend=1990 - Old School 88
