Straight Boom (Barefoot International)
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32461
Printed Date: November-17-2024 at 12:40pm
Topic: Straight Boom (Barefoot International)
Posted By: NCH20SKIER
Subject: Straight Boom (Barefoot International)
Date Posted: December-13-2013 at 9:28pm
The new boat will take a straight boom so I am looking to either trade the contour section I have for a straight section or simply purchase.
------------- '05 206 Limited '88 BFN
Posted By: fanofccfan
Date Posted: December-13-2013 at 9:44pm
+1^
Or you can have a machine shop build an adapter for your contour. That's what I did and it works fine. It consists of a piece of aluminum pipe that fits over the round and flat part of the boom. They then welded a piece of flat stock into that pipe at the proper angle so the contour boom is parallel to the floor. I will try to get a picture of this as it is becoming very hard to explain..
Posted By: Hollywood
Date Posted: December-13-2013 at 10:16pm
Greg, so your current section sweeps up and back? Email me pics, wondering if I can make it work sweeping up and forwards (so rolling it 90).
Posted By: IAughtNaut
Date Posted: December-13-2013 at 10:34pm
if its like mine it goes out from the clamp, up, then out over the gunnel...and the way mine fits in the clamp you have to rotate it 180, 90 doesn't match up.
------------- bring the ruckus http://www.correctcraftfan.com/diaries/details.asp?ID=5347" rel="nofollow - 2000 Pro Air
Date Posted: December-14-2013 at 12:11am
Oh, So it's not a square at the clamp end? I could handle drilling a hole but I don't have a mill so that would be a lot of filing.
Date Posted: December-14-2013 at 12:53am
mine's a beveled rectangle, his may be square but I doubt it
Date Posted: December-14-2013 at 9:26am
How do I post a photo from my iPad? It keeps saying I have already have posted a file with that name. It's is already resized smaller so it should fit the size constraints. I could email it if anyone is interested.
Date Posted: December-14-2013 at 9:36am
HW - will be at the lake next week and grab some pic's. The end that goes into the clamp is square and not beveled. I have not installed on the boat but will give it a go next week. Thinking that Santa needs a barefoot pic
Date Posted: December-14-2013 at 9:38am
Bill. You could always email the pics directly gskfossett@carolina.rr.com
Date Posted: December-14-2013 at 1:12pm
I will do that. tried from he pc and it wouldn't work either.
Posted By: 75 Tique
Date Posted: December-14-2013 at 2:06pm
If its just a case of getting the message that you've already uploaded that photo, you can just change the name of the photo you are trying to upload.
Date Posted: December-14-2013 at 4:03pm
I tried that too. Emailed the pic to Gregg and he was going to try uploading it later.
Date Posted: December-14-2013 at 7:19pm
Renamed the file and tried it. I will give it a go from the computer as opposed to the iPad
Date Posted: December-16-2013 at 9:49am
Im sure pictures will help clear up the confusion, but I think some terms are getting mixed up here. It sounds like Adam has a BI "Straight Contour" which has a single vertical curve in it. It sounds like Greg is selling the more common "Universal Contour" which has a compound contour- it curves both up and aft... and was designed for boats that had windshields that extended further back than the pylon (late 80's and early 90's Prostars, etc).
The Universal Contour can in fact be installed backwards (so it curves up and forward) on some boats. I believe Alan had one installed this way on his '81, and I know Brad has one set up this way on his '86 2001. I would imagine a '88 could be done without much of a problem. The issue, as mentioned, is the boss where it installs in the clamp... some are only set up for one direction (rectangular boss), others are set up for both (square boss). The square boss can be drilled in 2 directions to allow it to be used on either port or stbd, or alternatively, curve forward. Brad had a rectangular boss milled and drilled... so if youve got the tools, it can be done.
Date Posted: December-16-2013 at 10:04am
I believe that Tim is correct. I will try to upload a couple of pictures of mine below. While this set up work it is simply not the preferred set up. Still cannot load from the iPad. - will try the laptop and if no luck well who knows........
Date Posted: December-16-2013 at 10:15am
Tried again from the laptop and get a different error message - this says that the site may be under maintenance. Will need to try again later
Date Posted: December-16-2013 at 12:19pm
_ (_)
_ |_|
Which one does it look more like?
Date Posted: December-16-2013 at 12:47pm
The bottom one - essentially the end is roughly 1-1/4" square with two holes drilled through all four (4) faces.
Date Posted: December-16-2013 at 1:21pm
So you no longer want to use it like you previously did on the sport? I have a straight piece I would trade if yours will work for me. I need some better pics though, showing the for/aft angle, etc.
Date Posted: December-16-2013 at 4:53pm
I would prefer to go with a straight boom as opposed to the countour version. I will be back up at the lake late this week and can get some additional pictures / dimensions then.
Date Posted: December-17-2013 at 7:43pm
For those who are able to post pictures you must have super powers. I have tried again and refuse to accept that I am this computer illiterate. I am off to have a good cry (in my beer).
Date Posted: December-17-2013 at 7:47pm
Link from a third party site, uploading directly to CCF doesn't seem to be working.
Date Posted: December-18-2013 at 12:02am
Date Posted: December-18-2013 at 12:09am
Not to threadjack, but Greg, I love that picture of your boat. Number 1, the boat's badass, and 2, if ever there was a happy dude standing in his new boat, that's it!
Date Posted: December-18-2013 at 12:12am
Looks like this May work this time
Date Posted: December-18-2013 at 12:26am
Going to try this again
Will also try to upload Bills custom attachment
Date Posted: December-18-2013 at 12:30am
Thanks Adam, can't tell how much I am looking forward to spring / summer. I have already put in for vacation for the month of May.
Date Posted: December-18-2013 at 12:50am
Nice work Greg. My adapter may not work you because of your tower.
Date Posted: December-18-2013 at 1:04am
NCH20SKIER wrote:
Thanks Adam, can't tell how much I am looking forward to spring / summer. I have already put in for vacation for the month of May. | I heard that, my boat's getting a makeover at uncle reid's house right now, and I've already got feb, march, and april booked
Posted By: RobertV
Date Posted: January-07-2014 at 7:34am
Greg, Did you ever work this out? I'm looking for a complete boom and think that I could make yours work on my 86 2001. Let me know if you are interested in selling and how much. Robert 914 four nine four 8747 cell
