Replace Dash Pod 93 Sport
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32504
Printed Date: September-26-2024 at 8:13pm
Topic: Replace Dash Pod 93 Sport
Posted By: jimsport93
Subject: Replace Dash Pod 93 Sport
Date Posted: December-18-2013 at 1:03pm
Recently bought a used, blank dash pod to replace the pod on my 93 Sport. My current pod looks good cosmetically. However, two of the four mounting locations on the pod had pulled through. The pod moves around al little with wave action. Also, the yellow and red switch and radio panels have cracked corners at the screw mounting holes. So, I have to swap all the gauges, switches. panels and ignition breakers from the old pod to the new one. Quite a birds nest of wiring to sort through on the back of the pod. Any helpful tips, tricks, ideas to make the job a little easier and keep if organized?
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=2798 - 93 Sport Nautique
Posted By: Air206
Date Posted: December-18-2013 at 1:07pm
I think it would be easier to repair the back side of the pod - esp. if yours looks good. There will be folks out there that need a cosmetic and functional replacement to take the spare off your hands.
------------- https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206 http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot 78 SkiTiq
Date Posted: December-18-2013 at 1:08pm
Sorry guys. Not able to post a picture of the dash.
Date Posted: December-18-2013 at 1:13pm
Steve, was going to send the leftover blank pod to TXFoilhead when I am finished. I do not feel confident in repairing the pulled out mounting holes on the current pod. Have seen some threads in the past about doing that. May have to give them another look. Would rather avoid re wiring and replacing everything.....looks to be a time consuming process, and a real PITA!
Posted By: Gary S
Date Posted: December-18-2013 at 11:03pm
I have the same problem,looks way easier to repair than to replace. I have not had any time to check it out either I assumed that the dash harness would unplug so you could remove the whole dash so that you could work on it out of the boat?
Posted By: KRoundy
Date Posted: December-18-2013 at 11:36pm
My experience with dash pods from roughly 1 year ago: http://kroundysboat.wordpress.com/2012/12/29/dashboard-update/" rel="nofollow - Kevin's Dash Pod
Cutting and splicing back together all those wires is a real labor of love. It took me a couple of evenings to strip, splice and marine-shrink all those wires. Happy with the end result - but if you can avoid I'd recommend doing so.
Kevin
------------- Previous: 1993 Electric Blue/Charcoal Ski Nautique Current: 2016 Ski Nautique 200 Open Bow
Posted By: barefootjames
Date Posted: December-19-2013 at 12:32am
I had to repair the screw holes on my previous boat(1997SNCB). The repair seemed to last. I would also try to locate a wiring diagram specific to your boat, or at least a similar boat of that year. If you decide to replace the dash, I would label all the wires first. On the gauges, typically there is a ground, a sensor input to each gauge, and of course a light input too. I would also take one or more pictures before disconnecting any wire. I would also label the circuit breaker inputs, and possible the switch location(ie. top to bottom). When you make the switch, I would disconnect all of the gauges first, if possible I would try to remove the circuit breaker panel as one piece, or remove the circuit breakers separately without disconnecting the wires that are attached to the circuit breakers. Then I would remove all of the gauges from the old dash, then install the gauges into the new dash. Then I would remove the harness with the circuit breakers attached if possible. Pictures, and labels will be your best help when installing the harness into the new dash. ABOVE ALL I would NOT cut any wires, unless it was my last choice.
------------- 2005 Super Air Nautique Team Edition Blue/Black Reverse Color Hull 1997 Ski Nautique White/Blue/Black Sold 1997 Ski Nautique White/Black - Sold 1991 Barefoot Nautique White/Medium Blue/Light Blue - Sold 198
Posted By: Morfoot
Date Posted: December-19-2013 at 9:45am
Jim, Since Miss Grace isn't gonna be used for a while and you're jumping on this right away maybe a future road trip to your place might be in order to give you hand in repairing or replacing the pod? Unless of course you're wanting to get it done over the Christmas break. Think about it and let me know.
Date Posted: December-19-2013 at 11:30am
Tim, not going to do it during Christmas. This is a winter project. Road trip to my place would be greatly appreciated. It would be much easier to make the repair than to have to swap everything out. With your hi tech, aviation techniques I trust it would work. And will make it worth your while Thanks for the offer. Will take you up on that.
Posted By: Morfoot
Date Posted: December-19-2013 at 11:45am
Okay, will call soon to figure out a day to do it. I'm losing my 3 day weekends at the first of the year so it's back to 8 hr shifts for me. We'll get it done before ya know it.
Posted By: Toertel
Date Posted: December-19-2013 at 11:58am
Beer and Sport fixing, I'm in!
------------- 1994 Sport Nautique
Date Posted: December-19-2013 at 12:18pm
Sounds good Sebastian. Let's do it.
Posted By: TX Foilhead
Date Posted: December-19-2013 at 12:47pm
I think some epoxy and glass around the holes would work, not sure if that's a permanent fix since. Mine seems to be getting brittle best I can tell, and the cracking is either from vibration or me lifting the thin off a lot more than I should.
I'm still interested in any of 90's dashes to make molds with.
Date Posted: December-19-2013 at 12:51pm
Toertel wrote:
Beer and Sport fixing! |
Is there any other way to work on a boat?
Date Posted: December-19-2013 at 12:57pm
Don, I am still planning on sending you one of the dash pods to use to pop a mold. As soon as I get this done. May be a little while. Not too long since Morfoot has agreed to help. Need to make the repair and swap out the yellow and red switch panels with the new one (mine are cracked and chipped).
Posted By: JPASS
Date Posted: December-19-2013 at 1:35pm
I'm going to be fixing my dash on our '92SN. The plastic is broken below each breaker plate and the breaker panel screws no longer hold well.
I think I am going to make an aluminum plate/ring to go behind the breaker panel that has threaded inserts. I'll either sandwich this between the front and rear side of the opening or I'll simply epoxy it into the dash pod. I'll use aluminum machine screws to fasten the panel to the dash. Hopefully a permanent fix.
Not looking forward to removing all of the wiring to get the dash off to do the repair, but can't see any other way of doing it.
Date Posted: December-19-2013 at 6:29pm
Everybody can relax. Promise not to have any chain saws on the jobsite when Morfoot comes over to help
Posted By: Hollywood
Date Posted: December-19-2013 at 7:25pm
Or filet knives.
Posted By: Morfoot
Date Posted: December-20-2013 at 8:49am
If it takes a chainsaw to do the job you got bigger problems then just a dash pod cracked.
HW it's JBear you gotta keep filet knives from. I arrived on the seen after he nearly cut his thumb off.
Date Posted: December-21-2013 at 4:23pm
Just having a little fun at your expense Tim. I really do appreciate you offering to help. Looking forward to getting together
Posted By: Gary S
Date Posted: December-21-2013 at 4:52pm
While we are on the dash subject,any ideas on what to do with this chipped lower edge? Zach does not have any,other dealers web sites don't list them. Is it basically plastic with a decal over it?
Date Posted: December-21-2013 at 5:43pm
Gary, replacing those two red and yellow (starboard side has red on it too) panels was one of the main reasons for my purchase of the used pod. Had never seen a pod for sale, that fit my boat, during the last seven years on the site. Have seen a few of those yellow and red panels come available, but none to fit mine and yours.
Posted By: fanofccfan
Date Posted: December-21-2013 at 6:00pm
I had the same problem on my 96. I sure thought someone would have come up with a sticker replacement by now especially with the magnitude of creative people that hang around here.
Date Posted: December-21-2013 at 6:12pm
I think Marty has those, if not he could make them if you sent him those. I vaguely remember someone putting those stickers on a plate and the putting another clear plate over the top to protect the sticker before mounting it back in the dash.
Date Posted: December-21-2013 at 6:57pm
Marty did have some panels, but not the same ones that would fit my 93 Sport (same as the one Gary shows a pic above).
Posted By: winniskier
Date Posted: December-21-2013 at 8:15pm
The holes on my pod cracked and broke to the point where they did not work. I glued, maybe epoxied, some form of plastic to the backside and drilled new holes. The fix has held up for two years.
After I was done, I stumbled onto a web video of someone fixing a cracked snowmobile cowling. Seemed like just the right product and technique. I've had it the back of my mind in case my fix fails.
------------- Jim
Posted By: lewy2001
Date Posted: December-22-2013 at 7:37am
I repaired the dash pod on my 89 with this product http://plastex.com.au/product-info/4579343177" rel="nofollow - Plastex
Posted By: JPASS
Date Posted: December-22-2013 at 9:17am
I was planning on using http://www.westsystem.com/ss/g-flex-epoxy" rel="nofollow - G-FLex
I've always had excellent results when using this product. I think it's like $50, but it lasts a long time and can be thickened as needed.
Posted By: KRoundy
Date Posted: December-23-2013 at 1:56am
Marty can make those decals. Very nice quality reproductions. The plastic you have to repair or replace.
Posted By: velde99
Date Posted: January-29-2014 at 8:52pm
So I made the two lower dash panels for my boat. I hooked up a couple other CCF buddies with new panels as well. I only had the overlay for the right side. The left is still a work in progress. But this is the front and will post pictures of the back.
Posted By: velde99
Date Posted: January-29-2014 at 8:55pm
Date Posted: January-29-2014 at 8:57pm
Is the lettering for the buttons in a picture file or can you change the text? I've used all my accessory switches and would like to have them labeled appropriately when this project comes up.
Posted By: velde99
Date Posted: January-29-2014 at 9:37pm
I made the plastic panels- overlays are the Originals from CC.
Posted By: JPASS
Date Posted: January-29-2014 at 9:55pm
My dash had cracks where every self tapping screw attached. It was in pretty bad shape. I wound up using some G-Flex epoxy on all the cracks and then glued in these threaded inserts I got from my airplane mechanic buddy. He's assured me they are weatherproof.
I still have some work to do as far as sanding things flush and painting the epoxy black, but you get the point. I know it's not original, but the damage was pretty severe and replacements are hard to come by.
Posted By: KRoundy
Date Posted: January-30-2014 at 12:48pm
JPASS, That looks good. Curious - why do you want to paint the epoxy?
Kevin
Posted By: JPASS
Date Posted: January-30-2014 at 1:08pm
Kevin |
Just to make it look a little cleaner. I know it's on the back, but I will be painting the screw heads black as they are now stainless and stand out. Figured while I got the paint out why not touch it up??
Posted By: Morfoot
Date Posted: January-30-2014 at 1:45pm
Be sure to rough up the epoxy with sandpaper, scotchbrite, something or else the paint won't stick.
Posted By: JPASS
Date Posted: January-30-2014 at 4:16pm
Morfoot wrote:
Be sure to rough up the epoxy with sandpaper, scotchbrite, something or else the paint won't stick. |
Yeah I know. Not my first time painting over G-Flex epoxy repairs.
Posted By: N2Deep
Date Posted: January-30-2014 at 5:51pm
I made my own with a piece of Aluminum. Actually made 2 for each side and then cut the center out of the back plate to sandwich the dash between them so the screws weren't going thru the dash pod. Since I couldn't find replacement stickers I just used some Carbon Fiber wrap material over the top piece. And need to figure out some way to label everything but haven't got that far. Right now I just know where everything is. Not original but since it wasn't available I didn't have much of a choice.
------------- 1991 SN pulled by a 2010 Tundra
Posted By: JPASS
Date Posted: January-30-2014 at 11:39pm
N2Deep wrote:
I made my own with a piece of Aluminum. Actually made 2 for each side and then cut the center out of the back plate to sandwich the dash between them so the screws weren't going thru the dash pod. Since I couldn't find replacement stickers I just used some Carbon Fiber wrap material over the top piece. And need to figure out some way to label everything but haven't got that far. Right now I just know where everything is. Not original but since it wasn't available I didn't have much of a choice. |
Hit up Marty Mabe on here. He should be able to get you the correct decals.
Posted By: velde99
Date Posted: January-31-2014 at 12:23am
Spoke with House of Plastics in Orlando today. He said he can reproduce the pods. Just need enough people to buy them. He needs to see one to see what is needed for the tooling. I will be following up with him tomorrow.
Posted By: JPASS
Date Posted: January-31-2014 at 12:25am
velde99 wrote:
Spoke with House of Plastics in Orlando today. He said he can reproduce the pods. Just need enough people to buy them. He needs to see one to see what is needed for the tooling. I will be following up with him tomorrow. |
I'd be interested to hear more about this.
Date Posted: January-31-2014 at 9:30am
Are we talking about the pod (plastic dash with holes for gauges and panels covered in vinyl) or panels (flat plastic with holes for breakers and LED's)?
Posted By: velde99
Date Posted: January-31-2014 at 4:01pm
The "pod" holds gauges and speedos.
Date Posted: January-31-2014 at 4:11pm
Ooooh, cool! Can he do both the basic shell, as well as the vinyl overlay (I assume its a vacuum process)? If he can make it out of something stronger than the original so that it doesnt crack, that would be pretty sweet.
Posted By: velde99
Date Posted: January-31-2014 at 4:38pm
I'm on it. It will be plastic- since that's what they do- but maybe they can reenforces it with better tech from today? Still waiting for his call. I explained to him what it was and sent pictures. The vinyl is heat shrunk on- so I will ask if that is a possibility. I'll keep everyone posted.
Posted By: JPASS
Date Posted: January-31-2014 at 4:49pm
Being that I am local, let me know if there is anything I can do to help out with this. I have my pod off at the moment for repair, but all the gauges and wiring harness are all still installed.
Posted By: KRoundy
Date Posted: January-31-2014 at 5:08pm
I have a thrashed-out old pod (1993 Ski Nautique) with torn-out attach points that I'd be willing to donate to the cause. It would be great if there were a way to reinforce the attach points and thus make the new pod more durable.
Posted By: JPASS
Date Posted: January-31-2014 at 5:47pm
Gluing down the vinyl that was peeling up around the edges.
