Stringer replacement
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32691
Printed Date: November-17-2024 at 9:38pm
Topic: Stringer replacement
Posted By: captbob626
Subject: Stringer replacement
Date Posted: January-18-2014 at 5:17pm
I am replacing my stringers in an 83 nautique. Wanted to take the engine bed out but cannot get it over the ski tow pole because on he ring. I have the bed loose but cannot figure out how the ski pole comes out. Any suggestions. The pin at the bottom. Can't drive out because stringer is in the way to drive it out. Not sure ow to proceed. Ant thoughts would be appreciated.
Bob Meimbresse
Posted By: storm34
Date Posted: January-18-2014 at 5:44pm
Don't cut it off.
There's two roll pins you can punch out and then pull the ring.
Might help to heat the pylon. Use a piece of wood in the ring to twist and lift.
Date Posted: January-18-2014 at 5:54pm
I took the 2 pins out but couldn't move the ring. I'll try a little more heat.
Bob Meimbresse
Date Posted: January-18-2014 at 6:44pm
Bob,
There are several threads on the frustrating process of removing the ring from the pylon. They can be real stuck due to corrosion. The most successful method is to hook up a means of vertical lift (come-a-long or hoist) to the ring. Then penetrating oil helps. (50% ATF and 50% acetone is best) Twist the ring back and forth while applying the vertical pull.
Date Posted: January-18-2014 at 8:56pm
Thanks Pete,
I'll put some heat on it tomorrow and give it a try with my overhead chain. Don't want to pull post out of bottom. Guess best if I refasten the engine bed.
Bob Meimbresse
Date Posted: January-19-2014 at 10:13am
If you do manage to get the ring and finger off, what then? Leave the pylon in the boat while you do a stringer job around it? That's not a good solution... I'd be focusing on getting the pylon out instead of getting the topper off.
Date Posted: January-19-2014 at 10:19am
Tim,
Good point!!
Date Posted: January-19-2014 at 11:25am
I can't get the pin out at the bottom of the pylon. I can't get a punch between the stringer and pylon to get the pin out. Any ideas? Would love to get pylon out.
Bob Meimbresse
Posted By: SNobsessed
Date Posted: January-19-2014 at 11:41am
Aren't you taking the stringers out anyway? Take stringer out 1st, then punch out pin?
Date Posted: January-19-2014 at 12:50pm
It would be helpful if I could get the engine bed off first. Top is held in with ring so cant get bed off top without removing ring or entire pylon.
Bob Meimbresse
Date Posted: January-19-2014 at 12:59pm
How hard would it be to drill the bottom pin out?
Bob Meimbresse
Date Posted: January-19-2014 at 1:02pm
You have 10" to get a punch in there... Why are you claiming there's no room?
Chris, the pin in question goes through the pylon and the cup glassed to the hull, it's not attached to the stringers.
If you can't get the pin out, then I'd grind the cup free from the hull so you can work on it out of the boat.
Date Posted: January-19-2014 at 1:10pm
I can get the punch in there but can't get enough swing on the hammer to knock the pin out. How large is the cup and is that my best option to grind it out?
Bob Meimbresse
Date Posted: January-19-2014 at 7:11pm
Got the ring off so I can get the engine bed out and proceed from there. I'll Try to get the pylon out as I get the stringers out. Hope it's not as tight as the ring.. There seemed to be a lot of corrosion in the pole lodging the ring I was surprised for a fresh water oat.
Bob Meimbresse
Date Posted: January-19-2014 at 7:53pm
Bob,
They can be real stuck due to corrosion. .
It doesn't surprise me at all. Keep in mind the pylon in not anodized.
Date Posted: January-21-2014 at 12:06am
Got the engine bed out and the starboard main stringer. Very messy dust from cutting with diamond blade. It was in pretty solid . Back was fairly dry, front wet and came out easily .
Bob Meimbresse
