Loose rear hatch lift bracket
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32709
Printed Date: November-17-2024 at 9:52pm
Topic: Loose rear hatch lift bracket
Posted By: Gary S
Subject: Loose rear hatch lift bracket
Date Posted: January-22-2014 at 4:58pm
When I put the boat away this fall I disconnected the rear hatch lift
ram so I could leave the battery disconnected. When I did I noticed
that the top bracket was loose and would not tighten up. Does anyone
know how it is attached? I assume the fix involves removing the
upholstery,how does that come off?
Posted By: flipflop
Date Posted: January-22-2014 at 5:54pm
The bracket is mounted with three small nuts and bolts. The only way to really tighten them is to pull the upholstery up a little and slide a wrench in there to hold the backing nut. There is also a little plate that goes over the nuts so you can't really feel them through the vinyl. It's almost impossible to get the staples back by ordinary means because the hinge end hangs over the edge of the sundeck. I have no idea how they installed it from the factory.
Posted By: alfredmatte
Date Posted: January-31-2014 at 6:30am
Thanks for this useful information. Now it would be easy to lift the bracket and hanging it on the wall.
________________________________________________
http://www.decoralamerica.com/articles/wood-grain-powder-coating/" rel="nofollow - Read on this page about decoral.
