early 351W block wanted for stroker build
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32811
Printed Date: November-17-2024 at 12:51pm
Topic: early 351W block wanted for stroker build
Posted By: DayTony
Subject: early 351W block wanted for stroker build
Date Posted: February-09-2014 at 11:38pm
looking for an early (i believe pre-"76" ) windsor block
after a season with my FN i would like some more power. but don't want to sacrifice a good running motor to start build.
must be nearby me for it to be worth it, Boston Ma.
dont need heads or intake etc.
Posted By: JoeinNY
Date Posted: February-10-2014 at 3:05pm
Why are you looking for an early block?   Your likely going have a stroker crank that will work with a one piece main seal and has no wick lines, that would be easiest with a later model block.   Depending on what you are planning to do and the quality/availability of the machine shops in your area you may want to consider getting machined bare block from
http://www.fordstrokers.com/machined-bare-blocks/351-windsor-roller-block.html" rel="nofollow - Ford Strokers
I have used a couple they are well done, although I did have them finish honed after I purchased and measured pistons. Being a marine application and them not knowing what pistons you are using you should discuss ahead of time what exact piston to wall clearance you are going for..
http://www.correctcraftfan.com/diaries/details.asp?ID=1477 - 1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Posted By: DayTony
Date Posted: February-10-2014 at 3:52pm
thank you for the link, a little more than i wanted to spend on a block though.
I will be doing all the machine work myself so its not worth me paying for all the work already done.
I was under the impression the earlier blocks are the ones best suited for a stroker base. 69-76 is what i thought. am i wrong about this?
Posted By: TX Foilhead
Date Posted: February-11-2014 at 12:36pm
69 and 70's I believe are the blocks your looking for, although I really doubt you're going to build something where block strength will become an issue.   351's are good for over 500hp with a stock crank more with a forged crank. The Corral has lots of info about where the limits are and what blocks to look for.
Posted By: halfnelly
Date Posted: February-11-2014 at 12:48pm
'69-'74 351W blocks have more webbing and are stronger, but '69-'70 are a shorter deck height (9.480 vs 9.500) which would impact the parts needed for building a stroker. They're getting harder to come by and really aren't necessary under the 500HP level. '94-'96 blocks are a bit lighter duty but are roller cam ready.
Posted By: JoeinNY
Date Posted: February-11-2014 at 2:22pm
There isn’t a reverse rotation stroker crank out there with wick lines that can be used in an early two piece seal block.   So you are going to be into an 85ish plus casting if youre looking to stay right hand. And you will need to source the one piece rh rotation rear seal.
I haven’t had any trouble breaking old or new blocks.. if you are going to get serious might want to consider a stud girdle on any stock block.
