stuffing box question
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32915
Printed Date: November-17-2024 at 6:35pm
Topic: stuffing box question
Posted By: pholman59
Subject: stuffing box question
Date Posted: February-25-2014 at 6:13pm
My poor 93 ski, which has been awaiting its engine rebuild for almost two years, had a seized drive shaft to the packing material in the stuffing box. The boat has been a salt water boat, never more, but the shaft was pretty corroded to the point where it would of never sealed. In my ignorance, I took the shaft down to the machine shop to have them turn it down slightly to remove the peaks and valleys of the corrosion.Now I have a drive shaft that has two diameters. Its still plenty thick for strength purposes, but I'm wondering if my next move would be better to lengthen the stuffing box hose part as there is room to do this; or pack it with thicker packing material. Or should I just bite the bullet and take it back to the machine shop and have them build the shaft back up with bronze. That sounds expensive. I hope this makes sense.
Posted By: gR@HaM
Date Posted: February-25-2014 at 6:50pm
I would have thought you would be better off buying a new shaft fella, mine wasnt to expensive plus I had to get it shipped over to the UK. As most would recommend on here, go for an ARE double taper makes it much easier to remove/refit
------------- '82 Ski Tique
Posted By: dwouncmd
Date Posted: February-25-2014 at 7:22pm
I would question the safety of a shaft with with a portion turned away without a repair, so I would say no to using a longer hose to move the packing gland up the shaft or to try to seal by messing with the packing.
If the machine shop did not do it for you, you might consider checking the rest of the shaft for true with a dial indicator (I think they are more likely to be out of true aft of the strut). If the shaft is out of the boat and you have a known true surface (a granite counter top for example), you can check true by rolling it like a pool cue. If the shaft is not true, no need to consider further, get a new one.
Another thing to consider is ease of installation of the double taper shaft; that as well as accounting for the cost of repair to the old shaft may make a new shaft worth it. If I recall, the ARE shaft from Discount Inboard Marine (Ski Dim) is about $400 shipped (sorry to mention the US price Graham; I hope that does not make the pain you feel finding/buying parts worse than it already is).
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=6535&sort=&pagenum=2" rel="nofollow - 89 SN <a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
Posted By: gR@HaM
Date Posted: February-25-2014 at 7:59pm
It's all good Wayne I have selective amnesia when it comes to what I spend on boat parts
Date Posted: February-25-2014 at 8:35pm
I agree with not using a longer hose and the potential weakness of the shaft. Did the shop check the runout of the shaft (before and after machining)? If not, I'd wonder about the integrity of that "machine shop"!! It should not exceed .003" What was the RMS finish they machined to?
Get a NEW SHAFT!! Yes on the ARE shaft system!!
Posted By: Waterdog
Date Posted: February-25-2014 at 11:05pm
Don't chance it, get a new shaft. The old one has seen a lot of heat. Many have failed from fatigue. When they do it takes the prop to the bottom with it. You may want to source a rudder too.
The fence at White Lake Marine is lined with failed drive shafts. (pretty cool really)
------------- - waterdog -
Date Posted: February-26-2014 at 3:05pm
Yeah, I think its new shaft time. Whats another $400 on a 21 year old boat. I'd hate to blow a $6000 rebuild on a $400 dollar part! Hahaha
Posted By: gR@HaM
Date Posted: February-26-2014 at 5:57pm
Photos!!!!!!
Date Posted: February-27-2014 at 5:19pm
Photos coming when its completed. I dont want to jinx it.
Posted By: gR@HaM
Date Posted: February-27-2014 at 6:40pm
If you've spent 6k already it can't possibly go wrong
Posted By: MrMcD
Date Posted: February-28-2014 at 1:49am
If the shaft is straight and still fits tight in the trans mount/coupler you can emery cloth the shaft smooth where the rope seal runs. The rope seal is very moldable and will seal just fine on the reduced surface shaft. A new shaft is ideal but the rope seal is the least of my concerns. If smooth even if pitted the rope seal should be able to get you under 15 drips per minute. Smooth it with something like 600 and finish with a 1500 grit where the rope seal rides. This is for the budget constricted, if you have room to do it right you will get the best results. As you tighten the nut against the rope seal it will expand and the slightly smaller shaft is not an issue at all. The rope seal will make up the diameter difference. Make sure it is aligned correctly and your strut/cutlass bearings are good. Good Luck
