Depth Finder Loose Wire
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32960
Printed Date: November-17-2024 at 7:27pm
Topic: Depth Finder Loose Wire
Posted By: flipflop
Subject: Depth Finder Loose Wire
Date Posted: March-04-2014 at 6:53pm
Could anyone help with repairing a depth finder puck? I believe its the stock Faria Depth finder. (Boat is a 1999 Nautique) The wire has come loose from the puck and the puck is no longer glued to the hull. Can I just glue both back together or is there more to consider? Not sure how they work. Any help would be appreciated.
Posted By: Bri892001
Date Posted: March-04-2014 at 8:34pm
I'm going to guess that getting the wire re-connected to the puck is going to be a little tricky if it's disconnected at the puck side.
Do you have any pictures?
Posted By: backfoot100
Date Posted: March-05-2014 at 11:00am
If the wire is pulled out of the puck, that's sealed and you're SOL. Time for a new puck.
Eddie
