Distributer
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=33227
Printed Date: November-17-2024 at 7:26pm
Topic: Distributer
Posted By: Bones71
Subject: Distributer
Date Posted: April-01-2014 at 9:47pm
How do I identify my distributer brand ? Prestolite or Mallory? I have a 89 SN with a 351 Windsor. It could be either right? It has two screws holding it down. Doesn't one brand have the clip down? I want to replace my points. Thanks for the help. No I don't want to convert to electronic. Tony.
That money talks, I'll not deny, I heard it once: It said 'Goodbye'
Date Posted: April-01-2014 at 11:23pm
Post a picture. Your boat would have had a Prestolite screw down. Prestolite also made a clip down version that PCM used through ~87. Both use the same points kit, only the cap/rotors are different. I don't recall Pcm using Mallory past the mid 70's (when they were still Waukesha). That doesn't mean someone don't swap your original out though.
Posted By: Bones71
Date Posted: April-01-2014 at 11:56pm
Here is a couple pics. Thanks Tim.
Date Posted: April-02-2014 at 12:16am
I'd guess it's the original (screw down Prestolite) but it's hard to be certain from those pics. The caps are a lot more distinctive between styles than the points base plate.
Posted By: Bones71
Date Posted: April-02-2014 at 12:25am
This help? Thanks.
Date Posted: April-02-2014 at 1:13am
Yeah, Prestolite screw down.
Posted By: phatsat67
Date Posted: April-02-2014 at 12:40pm
Glad you are keeping the points in it. That would be an 87 and newer distributor.
Make sure you keep the advance mechanism lubed up. I forget to do that sometimes and have had it create an erratic idle circumstance. They recommend a few drops of oil in that little sponge in the top of the shaft under the rotor.
Posted By: Bri892001
Date Posted: April-07-2014 at 7:13pm
That 8 sided thingamabob is the cam right? Is it me, or does one side look a little worse for the wear:
Posted By: SNobsessed
Date Posted: April-07-2014 at 8:43pm
It just looks like corrosion on the shoulder, it's the face of the cam that counts.
