1984 Ski Nautique 2001 Oil Change
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=33509
Printed Date: November-17-2024 at 4:32pm
Topic: 1984 Ski Nautique 2001 Oil Change
Posted By: Nickkitko
Subject: 1984 Ski Nautique 2001 Oil Change
Date Posted: May-05-2014 at 12:31pm
Hi All -
I am looking to get my boat, newly purchased, going for the season. I have not owned a boat yet, so I am new to most of this stuff.
What all do I need to do to get it up and running for the season? Last year it did not see the water - maybe 1 hour logged.
Has the Ford 351 engine with about 500 hours total on it.
Thanks for the help
Nick
Posted By: dwouncmd
Date Posted: May-05-2014 at 5:52pm
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=27356&PN=1&title=ccf-faq" rel="nofollow - Look here at the FAQ section. It has winterizing information (the same link has de-winterizing information).
Cut and paste this into Google [site:www.correctcraftfan.com] and add "checklist" or "winterize" or "oil" or whatever you have a question about, and you are likely to find more advice than you have time to read.
I also like this post if the boat is new to you...things to think about
Originally posted by baitkiller baitkiller wrote:
The Holley will not bolt up on the Q jet bolt pattern without a new intake or adapter. You will also need to loose the wedge you most likely run now. Clean up the Q jet and run it for a while before changing stuff. An easy upgrade is the marine AFB that will bolt right on your wedge. it is a very reliable carb with the same performance as the Holley (IMO) if the Holley has a HP edge you'll never see it in a boat. The steel fuel lines, throttle linkage etc. etc, will all be a pain.
If it were my new-to-me boat I would set the maintenance clock back to ZERO.
By this I mean do all periodic maintenance so you have a fresh time line. I feel this will give you better return to dollar for the summer than a Holley carb.
Cap and rotor
Clean the Q jet
All fluids and filters, including gear oils.
Impeller
Balance the prop and lap to the taper.
Alignment and packing.
New battery if older than 2 years. Clean all connections, dash ground etc.
From you local I would also pull the risers to inspect / service gaskets. Be ready for new ones if the boat has been run in the brine.
Hope that helps...
http://www.correctcraftfan.com/diaries/details.asp?ID=6535&sort=&pagenum=2" rel="nofollow - 89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
