awesome BUCKET METHOD video
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=33560
Printed Date: April-09-2025 at 12:13am
Topic: awesome BUCKET METHOD video
Posted By: malcolm2
Subject: awesome BUCKET METHOD video
Date Posted: May-12-2014 at 5:23pm
[youtube]PKky09u1fGU[/youtube]
Hey admins, I would use the above code on another forum to EMBED a youtube video into my post on their forum. Is there a way to embed a video on this forum?
The embedding basically shows the thumbnail of the video and allows you to watch the video while still on this site vs. clicking a link and going to youtube to watch the video.
Anyway on to the subject. For those of you like me that want to know and like the "show me" method, this 6 minute youtube video is pretty good and does a good job of showing you exactly how to run a boat engine with the bucket method.
My searches on this forum left me with alot of explanations, and some videos that only showed partially what you needed to see. If I missed a better video of a Nautique using the bucket method, please share.
http://www.youtube.com/watch?v=PKky09u1fGU" rel="nofollow - SAIL BOAT engine using the bucket method
Posted By: JPASS
Date Posted: May-12-2014 at 6:12pm
you mean like this?
'92 Correctcraft Ski Nautique
Posted By: ny_nautique
Date Posted: May-12-2014 at 6:32pm
the code is TUBE in the brackets, not YOUTUBE
Makes perfect sense, right?
- Jeff
1999 Ski Nautique
Date Posted: May-12-2014 at 6:34pm
A guy on the TeamTalk forums posted a good video of how fast the engine sucks 5 gallons. I'll post it when I get home.
- Jeff
1999 Ski Nautique
Posted By: malcolm2
Date Posted: May-12-2014 at 6:35pm
zackly!
thanks
so you drop the "you" on both ends and put the complete URL between. I'll remember that.
Date Posted: May-12-2014 at 6:44pm
You don't need the complete URL, just the ID will work too. But I do believe you need all CAPS for TUBE
- Jeff
1999 Ski Nautique
Posted By: 74Wind
Date Posted: May-12-2014 at 7:07pm
Good video, now all we need is a fiberglass cockpit with scuppers for spillage/overflow
1974 Southwind 18
1975 Century Mark II
Posted By: quinner
Date Posted: May-13-2014 at 12:42pm
Unless I missed it Mr Blow Boat forgot a very critical step, you should drain ALL the water from the block, manifolds, trans cooler, etc. before adding (sucking up) the anti-freeze.
Posted By: JPASS
Date Posted: May-13-2014 at 1:26pm
Caps doesn't matter. Just insert image and change "IMG" to "tube" and it should work. Also be sure to remove the "s" in "https"(if it's there in the link). I've noticed some videos won't embed if it says "https" instead of "http".
The link I'm posting is:
https://www.youtube.com/watch?v=JfdbxrFmuEY
I change https to http:
http://www.youtube.com/watch?v=JfdbxrFmuEY
Posted By: malcolm2
Date Posted: May-13-2014 at 2:40pm
So would the draining be critical? Once you start to see RED coming out of the tail pipe, wouldn't you have filled the water jacket, manifolds, pumps, etc...?
Clark
Posted By: Hollywood
Date Posted: May-13-2014 at 2:54pm
First question: yes
Second question: no
If the thermostat never opened you pumped out what you sucked up and the engine is still full of water.
If the thermostat does open, you just dilute the red with water, now making it pink.
Drain the engine first and suck up exactly what you want in the engine, it's foolproof.
Posted By: malcolm2
Date Posted: May-13-2014 at 3:00pm
Originally posted by Hollywood Hollywood wrote:
First question: yes
Second question: no
Yes, the T-stat....That is the "thing" my PO took off. I have added easy to open drains so the draining is not an issue, In years past, with an I/O boat, I would run the engine 'til the stat opened, you could see steam from the exhaust, open the pipe with the red stuff in it and let the red stuff flow, 'til it started coming out of the exhaust.
Thanks
Date Posted: May-13-2014 at 3:09pm
^ still wrong. steam doesn't ABSOLUTELY mean the t-stat is open, far too subjective
Posted By: bkhallpass
Date Posted: May-14-2014 at 2:15pm
Good Video.
I've found the best method to winterize a boat is to live in California.
BKH
Livin' the Dream
Posted By: bhectus
Date Posted: May-15-2014 at 4:22pm
Or Florida.
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
Posted By: Keeganino
Date Posted: May-15-2014 at 5:16pm
Ya'll crack me up!
Posted By: gR@HaM
Date Posted: May-15-2014 at 7:45pm
There's no way the supply from my garden hose is able to keep up with the RWP for any period of time!!
'82 Ski Tique
Date Posted: May-15-2014 at 10:48pm
Here's that Mastercraft video:
- Jeff
1999 Ski Nautique
