Another Gauge Question
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=33903
Printed Date: November-24-2024 at 5:54pm
Topic: Another Gauge Question
Posted By: racingnc
Subject: Another Gauge Question
Date Posted: June-19-2014 at 10:08pm
My 1986 Ski Martingue has VDO gauges in it my question is do I jave to replace all the sending units if I go to another brand
Date Posted: June-19-2014 at 10:54pm
Ask the manufacturer of the gauges you plan to use for the proper sender and it's Ohm range. We CERTAINLY can't answer since you didn't even tell us what gauges you plan on using!!!
Posted By: racingnc
Date Posted: June-20-2014 at 11:24am
My bad should have disclosed more info. Im thinking about replacing them with Teleflex due to more options.
Posted By: ArtCozier
Date Posted: June-20-2014 at 11:50am
Need more information about the gauges you plan to use. Most Teleflex gauges use the standard senders that are in the boat and engine. What "options" are you referring to?
One note.... If you do this, don't dispose of the gauges you remove from the boat if they work. No matter that the dials might be stained or faded. They are in demand by owners who want to "keep it original."
------------- "Art"
Posted By: backfoot100
Date Posted: June-20-2014 at 11:58am
The senders are resistance based. One 33-240 ohm sender shouldn't be any different than the next manufacturers 33-240 ohm sender. As long as the ohm values of the gauge match the ohm value of the sender you shouldn't have to change them. I reused all my factory senders when I replaced my gauges.
Eddie
Posted By: racingnc
Date Posted: June-20-2014 at 2:15pm
Posted By: racingnc
Date Posted: June-20-2014 at 8:14pm
Im talking about color style bezel look. The reason I am replacing them is because the plastic housings are cracking on the tops causing them to start to lean down and ready to break.
