75 Mustang
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=33909
Printed Date: November-24-2024 at 6:56pm
Topic: 75 Mustang
Posted By: jdlang22
Subject: 75 Mustang
Date Posted: June-20-2014 at 11:45am
Installing a rudder on my CC Mustang. Any one done this before or know something about the installation process. Looks pretty straightforward. I guess I just remove the top pins and then unscrew the big pieces and I guess packing is supposed to go in there?
Posted By: Skrobo
Date Posted: July-02-2014 at 5:12pm
i took mine off & re-installed on my 79 mustang a few months ago. it's as easy as it looks. there should be packing in there, but I don't want to give you false information about what size packing & if you should re-pack it. you may want to catch the rudder from hitting the ground one way or another when you take the bolts out.
Posted By: MustangMadness
Date Posted: July-03-2014 at 1:19am
Just use a jack stand or jack to support the rudder when you undo the packing assembly. You might as well drop the rudder and grease the shaft with a quality marine grease upon reassembly.
I like a 6' beam on a small lake... My Muscleboat
1975 Mustang 225 307RH
