Proper Grounding for Gasoline Tank
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=33922
Printed Date: November-17-2024 at 2:44pm
Topic: Proper Grounding for Gasoline Tank
Posted By: iplan
Subject: Proper Grounding for Gasoline Tank
Date Posted: June-21-2014 at 10:36pm
As ya'll know, I'm wrapping up the stringer job on my 1985 "Ski Naughty" ~ which is what I called them until I was about 7 or 8....
Anyway, I have two questions dealing with the tank area pictured here:
First Question: I cut the gasoline supply line thinking it would be easier to attach it to the fitting once the fitting was connected to the gasoline tank. Now I can not get the gasoline line to go all the way up to fitting, and there is a very large gap between were the hose needs to be and where it is currently, but no amount of strength will budge it any higher on the fitting. I was thinking about putting the hose in hot water, but wanted to check with you guys before I did something stupid.
Second Question: I was looking at a pre-disassembly picture of the gasoline tank area, and noted that there is a ground wire that runs to the gasoline inlet.....
I have no recollection of this part of the teardown process,and I would prefer not to blow myself up.
Any help you can provide would be appreciated.
I have a black ground wire and a purple ground wire. From the picture it appears the purple wire grounds to the tank,and the black wire goes to the gasoline inlet.
Would you agree?
And if so, how does the black wire connect to the gasoline inlet?
------------- 85 Ski Nautique 2001. Stringer replacement job completed July 3 2014. Exterior painted June 2015. The Trailer is next.
Posted By: DrCC
Date Posted: June-21-2014 at 10:49pm
Yes, good call on the hot water.
You need a connection between the tank and deck fitting.
I find it easier to set the tank, then install the deck fitting 2nd.
Posted By: Gary S
Date Posted: June-21-2014 at 11:02pm
Jonathan one of the 3 screws that hold the filler to the deck needs to be a machine screw with a nut ,put a ring terminal on the wire and connect it to that screw.
Posted By: DrCC
Date Posted: June-21-2014 at 11:10pm
And, Purple does not sound correct for a ground. Make sure you know where it goes and what it does before you hook it up. Meaning, follow it forward. Some one may have spliced a purple onto a black.
Posted By: CrazyCanuck
Date Posted: June-22-2014 at 1:31am
My 78 has a wire inside the rubber pipe that ground the deck fitting to the tank. Its just a bare copper wire running inside the pipe and under the hose clamps. Seems to work fine.
There was some plastic tie straps that hold the gas line loosly to the transom behind the tank on my boat. If you cut one, you may be able to pull the gas line up a bit to reach the barb.
Are you sure the black and purple wires are not for the sending unit?
------------- https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Posted By: TX Foilhead
Date Posted: June-22-2014 at 2:15am
If the Purple wire is a ground, change it purple is the color normally used for ignition. It so much easier to figure things out when they are wired with the correct colors.
