Engine swap?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=34058
Printed Date: October-08-2024 at 10:45am
Topic: Engine swap?
Posted By: Thisoldboat
Subject: Engine swap?
Date Posted: July-04-2014 at 10:06am
I have a 76 Ski Nautique with a cracked block (351 PCM). A friend has given me a 92 American skier with an Indmar motor, that I know is a ford engine ( not sure of the size), but presumed 351. Is it possible to remove exhaust manifolds, pulleys, wiring harness, etc., and drop the Indmar in place of the PCM? Thanks for any suggestions or comments in advance.
Posted By: SNobsessed
Date Posted: July-04-2014 at 10:48am
Check to see if it is a lefty before getting too far into the project.
Posted By: backfoot100
Date Posted: July-06-2014 at 7:19pm
That Indmar will definitely be a LH rotation. That would not work so well in your hull. You could tear it apart and put all your internals back into that block though.
Eddie
Date Posted: July-06-2014 at 8:19pm
I knew it was sounding too easy. I brought the boat home today and the motor looks great and actually turned over,and fired.
Posted By: MustangMadness
Date Posted: July-17-2014 at 10:01am
Can't you just put your old camshaft in the new block? Depending on them being both 351's of course.
------------- I like a 6' beam on a small lake... My Muscleboat 1975 Mustang 225 307RH
Date Posted: July-17-2014 at 10:41am
MustangMadness wrote:
Can't you just put your old camshaft in the new block? Depending on them being both 351's of course. |
You change out all the internals from the old block to the new one. Not just the cam.
Eddie
