1990 SN Fuel Starved
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=34112
Printed Date: November-17-2024 at 12:26pm
Topic: 1990 SN Fuel Starved
Posted By: astinespring
Subject: 1990 SN Fuel Starved
Date Posted: July-12-2014 at 3:48pm
my 1990 ski nautique with the PCM 351 is cranking and idling normally, but when we gun it, as if to pull a slalom skier out of the water, it just dies. You can hear the carb trying to pull a lot of air in, and it seems like there just isn't enough fuel to support what you're trying to do. We have just replaced the fuel filter/separator, thinking that was our issue, but apparently not. Just to clarify, the carburetor IS getting fuel. Help?
Posted By: Bri892001
Date Posted: July-12-2014 at 4:39pm
What if you ease it up to higher speeds. Will it be able to hold the higher speed?
Date Posted: July-12-2014 at 4:47pm
Yes it is holding the speed in a fake lake situtation, not sure with a skier behind.
Date Posted: July-12-2014 at 5:22pm
Hmmm... You'd have to see if it would hold the speed under load; like cruising in the water. Wouldn't necessarily have to be with a skier.
I'm just trying to figure out if it's just an accelerator pump issue, or a fuel flow/restriction issue.
Posted By: 65 'cuda
Date Posted: July-12-2014 at 5:51pm
Pump,
------------- Gary
http://www.correctcraftfan.com/diaries/details.asp?ID=941" rel="nofollow - 1965 Barracuda SS
Posted By: calebcl
Date Posted: July-12-2014 at 6:28pm
Co-Owner of that 90 ski here...last time the boat was on the water, it wouldn't die at full throttle while pulling a skier, but would die shortly after slowing back down to idle; as well as being starved when you gun it. What are the symptoms of the accelerator pump being bad?
------------- Caleb
Posted By: quinner
Date Posted: July-14-2014 at 2:50pm
I would start by removing and inspecting the anti-siphon valve, if it's clogged up and restricted it will starve the fuel flow.
Posted By: SNobsessed
Date Posted: July-14-2014 at 7:55pm
After that, try running boat with gas cap loose. It's rare, but the vent hose can get clogged.
Posted By: ezim
Date Posted: August-01-2014 at 1:10am
If you haven't fixed problem, check fuel pickup tube in gas tank. Take apart and check the two screens at top of pick up tube. They get clog with debris.
Posted By: 1987don
Date Posted: August-05-2014 at 1:00am
had similar issue last year with my 87 sn ...fuel line was collapsing from being ruined by ethanol in the gas. I replaced the line from the top of the tank to the fuel ands water separator and then from there to the carb...problem solved
