Throttle Issue
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=34237
Printed Date: November-17-2024 at 12:37pm
Topic: Throttle Issue
Posted By: tnplicky
Subject: Throttle Issue
Date Posted: July-25-2014 at 1:01am
'95 Nautique throttle issue ???
Was our skiing/boarding tonight. Everything was great until the last pull of the evening.
When engaging the throttle lever, the boat slips into gear like normal, but when putting the throttle "down" to go, nothing happens other than idle speed. The transmission goes into forward at idle, and goes into reverse, but no real power. Had to "put-put" back to the marina which wasn't all bad since it was a nice evening an there were a couple of beers left on the boat.
Anyway, I did not take the time tonight to do a search on the issue. Will do tomorrow, but if anyone has any insight on the issue, I would appreciate it.
I suspect a throttle cable issue or linkage issue, but I am just guessing.
Thoughts?
Posted By: Toertel
Date Posted: July-25-2014 at 2:56am
Did you check your transmission fluid?
1994 Sport Nautique
Posted By: tnplicky
Date Posted: July-25-2014 at 9:33am
I hadn't until you mentioned it, but the transmission fluid seems to be at the proper level and color is normal
Posted By: backfoot100
Date Posted: July-25-2014 at 10:02am
The brass barrel pin on the throttle cable has sheared where the cable connects to the morse control.
That or the throttle cable broke.
My guess is the barrel connector sheared off. They're designed to wear at that point.
Eddie
Posted By: tnplicky
Date Posted: July-25-2014 at 9:08pm
the throttle cable broke at the crimped end piece that attaches to the morse control
Posted By: KRoundy
Date Posted: July-26-2014 at 1:39pm
Eddie wins!
