Engine is out what other maintenace?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3431
Printed Date: January-16-2025 at 12:19pm
Topic: Engine is out what other maintenace?
Posted By: aodmailboxes
Subject: Engine is out what other maintenace?
Date Posted: April-23-2006 at 6:35pm
(Ford 351) Engine is out of my 79 Nautique. What other maintenance should I do while engine is out?? I want to get everything ready for summer.
New Hoses wires and plugs.
Exhaust hoses.
Impeller.
Motor mounts??
Bearing for drive shaft?
-Is this difficult??
Rope for drive shaft?
Any maintenace suggestions would be great.
Thanks
Posted By: M3Fan
Date Posted: April-23-2006 at 7:26pm
Date Posted: April-24-2006 at 12:22am
http://www.skidim.com/prodinfo.asp?number=R140001
What is a damper plate?
Anything else?
Posted By: 87sn2001
Date Posted: May-15-2006 at 8:19pm
the damper plat is like a flexplate on a car... it bolts between your engine and transmission..it dampins the engine torque to the transmsmion..there are springs on this plate that rust or break.. there not that expensive and easy to do when the engine is out..just sepporate the trans. from the engine and unbolt it from the engines flywheel..industrial supplie dealers sell theme cheap..there used on small bobcats..or any pcm dealer
Posted By: Tim D
Date Posted: May-16-2006 at 7:57am
Two things while engine is out, oil pan gasket and rear seal. If these go bad, you have to remove it again.
------------- Tim D
