velvet drive
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=34430
Printed Date: November-24-2024 at 3:58pm
Topic: velvet drive
Posted By: juno
Subject: velvet drive
Date Posted: August-17-2014 at 8:39pm
My prop continues to spin slowly in neutral as well as when the transmission is disengaged Is there an adjustment that can be made or is this within the realm of normalcy
Date Posted: August-17-2014 at 8:54pm
juno wrote:
My prop continues to spin slowly in neutral as well as when the transmission is disengaged Is there an adjustment that can be made or is this within the realm of normalcy | The clutch plates are warped and dragging. The trans needs a rebuild.
Posted By: juno
Date Posted: August-17-2014 at 9:09pm
After 250 hers Seems unusual that I would need a rebuild I read elsewhere that slight spin where you can stop it with your hands is not uncommon
Posted By: backfoot100
Date Posted: August-17-2014 at 9:30pm
juno wrote:
After 250 hers Seems unusual that I would need a rebuild I read elsewhere that slight spin where you can stop it with your hands is not uncommon |
There are several here that have had the same problem. You can probably live with it until you ding something when you can't control idle speed maneuvers anymore.
Pete's right about a rebuild being the fix.
Eddie
Posted By: juno
Date Posted: August-17-2014 at 9:41pm
So fluid change,tightening packing or a cable adjustment to tranny won't do much?
Posted By: CrazyCanuck
Date Posted: August-17-2014 at 9:54pm
My 78 SN has 2200 hours on the hour metre. ( someone must have left the key on for a whole summer.....lol) I have a dirty neutral just like you, and in my case, my boat does 2-3mph in neutral at 1500 rpm while the engine is warming up away from the dock. As soon as its warm enough to idle at 600, the DN is not as bad. My tranny doesn't slip to my knowledge...(so far touch wood) My boat does 45 mph with the original 13x13rh prop. I count myself very lucky so far on this boat. But I know that a new tranny or rebuild is in my future at some point.
------------- https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Date Posted: August-17-2014 at 9:59pm
juno wrote:
So fluid change,tightening packing or a cable adjustment to tranny won't do much? | John, I suspect the rebuild 250 hours ago was done by a HACK!!!
Posted By: juno
Date Posted: August-17-2014 at 10:12pm
I mean boat(1982 Mustang) has 250hrs on clock Do I believe it... maybe not but that's what it says and boat throughout looks spectacular
Posted By: SNobsessed
Date Posted: August-17-2014 at 10:28pm
Mine has had a dirty neutral for the entire 7 years I have owned it, & hasn't gotten any worse.
Posted By: juno
Date Posted: August-17-2014 at 10:31pm
I will give it a good run up on Moosehead Lake Maybe a long 40 mile run will clear it up
Date Posted: August-18-2014 at 8:37pm
juno wrote:
I will give it a good run up on Moosehead Lake Maybe a long 40 mile run will clear it up | No, it will not. The clutch plates are warped and are dragging.
Posted By: Riley
Date Posted: August-18-2014 at 8:41pm
You could try tightening up the packing a little bit.
Posted By: juno
Date Posted: August-20-2014 at 11:35pm
Tightened the packing 90 degrees and changed the fluid... no more spinning and when I disengage the transmission it does what is supposed to do... stop spinning
Posted By: P71_CrownVic
Date Posted: August-21-2014 at 10:18pm
8122pbrainard wrote:
juno wrote:
My prop continues to spin slowly in neutral as well as when the transmission is disengaged Is there an adjustment that can be made or is this within the realm of normalcy | The clutch plates are warped and dragging. The trans needs a rebuild. |
Pete is that more common to indicate a rebuild is needed or does slipping usually happen?
Mine still seems fine with 1K hours on it but I have a feeling I'll be doing a rebuild in the next couple years.
Posted By: Gary S
Date Posted: August-21-2014 at 10:41pm
Slipping is what causes the plates to heat up warping them then causing it to spin in neutral . Just make sure you keep it full of fluid,check it immediately after it's warmed up and shut off. Thousand hours are nothing
Date Posted: August-21-2014 at 11:20pm
P71_CrownVic wrote:
Mine still seems fine with 1K hours on it but I have a feeling I'll be doing a rebuild in the next couple years. | The Velvet drives are really pretty robust but still can be screwed up. I would have to say that at sometimes this trans was overheated.
Posted By: john b
Date Posted: August-21-2014 at 11:28pm
My Mustang ( that will be complete someday ) has 1652 hours on the meter and the trans does not have a dirty neutral. I can't say for sure that it has never been touched but the bolts still have paint on them. I don't know how long they last if cared for. http://youtu.be/QpXd1hLJMQ0" rel="nofollow - Neutral looks clean to me
------------- 1970 Mustang "Theseus' paradox" If everyone else is doing it, you're too late!
Date Posted: August-21-2014 at 11:31pm
My 64 X55 still has no problems ether. I suspect John isn't telling us the full story!!
Date Posted: August-22-2014 at 12:36am
Very interesting! I thought they were dicey after 1K hours but it sounds like that, with proper care and maintenance, they will last a lot longer. I have the fluid changed every other season and check it often.
Posted By: john b
Date Posted: August-22-2014 at 1:01am
Yours will last forever, Matt. I can't tell it from new and that probably extends to the internal parts. If you ever decide to sell that boat you will have many interested potential buyers. I can't imagine there is a cleaner one anywhere.
Date Posted: August-24-2014 at 5:07am
john b wrote:
Yours will last forever, Matt. I can't tell it from new and that probably extends to the internal parts. If you ever decide to sell that boat you will have many interested potential buyers. I can't imagine there is a cleaner one anywhere. |
Haha, well thanks John! I'm going to have this boat for a very long time if everything goes to plan. Maybe more, who knows. I'd love to have 4 or 5 lifts outside of my place on Island Lake full of inboards. But this one will be my special occasion boat....like for going to the Lower Unit Bar and Grille or the Blue Bayou.
